HI Guys,
I'm new to the forum but I'm not new to BMWs. I own E92 M3 superchargered with a low compression built motor. But now I have decided to get an E30 to fullfill my childhood dream of owning one.
I'm located in Taiwan , but I'm working with my friends in the USA to put a S54+tranny into my 1989 E30
has anyone have experience?
will the car understeer a lot after the transformation?
S54 swap in with a standalone ECU?
blue30
With that much power I don't think understeer will be a problem ;)
It is a technical compromise compared to a lighter engine, but in context I don't think it's massive, you can easily add or remove 50-100kg's around the car by having passengers or a full take of fuel, yes you can sometimes just feel the difference but it does not exactly ruin the car.
Hope the project goes well,
Neil
Neil
e21Jason
Have a search i think the last one was built by Turk who was seling the car
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
- Homo Hair
Just get the OEM ECU flashed..
glenn
- Engine Transplant Services
pm sent
eugene-taiwan
thanks for the input guys! the car is at the bodyshop right now just cleaning it up a bit. I'm going to lighten up the hood first just to get the weight off the front more. but just doing some studying on the E30 and engine swaps.
interesting so far
interesting so far
Dezzy
- CR24v it's a lifestyle
This is the guy to listen tooglenn wrote:pm sent
e30-EVN
^INDEED.!
Gunni
VEMS can run the dual vanos if you swap to cable.
