Engine mount Shock absorbers???
Post Fri Apr 06, 2012 3:03 pm
craigieeb
Post Fri Apr 06, 2012 3:07 pm
You could do with some of those on the anchor :D
but they are normally found on the 316/318's i do believe
http://bmwfans.info/parts/catalog/E30/2 ... on_damper/
TPS
Post Fri Apr 06, 2012 3:22 pm
316/318 have these, instead of hockey puck ones on the 6 cylinder cars.
BenHar
Post Fri Apr 06, 2012 3:26 pm
4-pots need something to stop them from shaking the car to bits.
Ben
redcar
Post Fri Apr 06, 2012 6:03 pm
The 316i and 318i have one of these which bolts onto the air intake side engine mounting arm, and then onto the subframe. The 318is doesn't have one though (possibly because the engine mounts themselves are filled with fluid)
Dezzy
CR24v it's a lifestyle
Post Fri Apr 06, 2012 8:57 pm
My Chromie had them fitted to its epic M10 donk before I had a few tweaks :D
Post Fri Apr 06, 2012 9:21 pm
Dezzy wrote:My Chromie had them fitted to its epic M10 donk before I had a few tweaks :D
I might have them too then as the MIGHTY M10 is still in there. I ll take a look tomorrow :D
