Common Problems
Grrrmachine
- E30 Zone Wiki / Team Member
I've got one or two more Wiki ideas to complete, and the biggest one is a list of Common Problems. There's plenty of ideas already in the Wiki, but I want to collect them all into one area, like this:
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
So tell me what you think is the most common irk, niggle or outright failure on these cars.
Looking at the blank links I'll suggest an interior one :
Loose seat back and/or seat recliner mechanism not locking in position ( Had this on most of my E30's - and its a "free" fix 99% of the time )
Solution to loose seat back :
Remove panel from rear of seat by undoing 2 screws at base
Locate the large cross-head screw near the bottom of each side of the frame upright section.
If the seat back is wobbly it is almost certain that these screws have worked loose.
Use a large philips screwdriver which is a good fit in the head of the screw to tighten these right up ( a small screwdriver won't do it and they'll work loose again )
Refit rear panel
Solution to backrest not locking in position :
Remove seat from car by undoing 2 bolts from back end of seat rails and 2 x nuts from the front
Remove the plastic cover from the pivot point where the handle is ( requires a large flat bladed screwdriver in order to avoid damaging the plastic screw )
This will expose the lever mechanism.
Spray WD40 liberally into the lever pivot/mechanism and work the seat backrest forward and backward to ensure the lubricant can get into where it needs to.
Repeat for the pivot point on the other side of the seat.
Replace covers and refit seat into car.
Hows that ?
Refit rear panel
Hows that ?
Captain_Birdseye
dunno what niggles are common yet, but this is a good idea.
Rtaylor2208
Speedo \ Rev Counter \Temp Guage \ Petrol Guage, Dash Lights, Heaters on No 4 and Horn not working.
They are all common asked questions and would fall into the instrumentation category.
Green
Blue temp sensor issues tend to creep up all the time.
MattTheHat325
Door/boot locks and central locking failures due to worn lock mechs etc. My e30, my e32 AND my e36 have all got temperamental locking systems in one way or another, BMW's weak point in my opinion, and another annoying niggle which can be fixed for a lot less than most would end up spending.
Grrrmachine
Thanks for the info guys; a lot of this has confirmed what I thought, which is why the page needs to be created. I'll see if I can get it stickied in the Tech Section in due course:
@Rob: thanks for the seat fixes, they've been added to the interior page
@RTaylor: a lot of the instrument issues are mentioned on the Instruments page, but I'll now ad them to a Common Problems section since, as you say, they're THAT common
@Matt: Locks will have their own page in due course, since they seem to be so troublesome.
For all the others, cheers! Keep 'em coming!
alexdejonghe
Great.
Far more effective having a central 'Go To' page such as this (complete with links), rather than have individual obscure pages that need to be accurately searched.
Go for it!
Go for it!
Dezzy
- CR24v it's a lifestyle
I just wanted to say well done for your efforts.Grrrmachine wrote:Thanks for the info guys; a lot of this has confirmed what I thought
Its a thankless task your doing and you just keep grafting on it
318isPMK
Grrrmachine
Awww, cheers guys. It's not completely thankless (I get all sorts of appreciative PM's) but that's not why I do it.
Anyway, gaaaaay
Anyway, gaaaaay
Dezzy
Thats exactly why you do it!Grrrmachine wrote:Awww, cheers guys. It's not completely thankless (I get all sorts of appreciative PM's) but that's not why I do it.
Anyway, gaaaaay
poolnoodle
A section of instrument cluster problems would be handy. A few very common ones - gauge earths and SI board / battery failure
