Oil feeds?
cypriot_boy_2k7
Post Thu Apr 05, 2012 4:59 pm
For the life of me i cannot find specific info on the m40.
Where are there High Pressure oil feeds on the engine or is there any other place?
seen some adapters but dont think they will go on an m40
http://www.thinkauto.com/takeoff.htm
Its to run a supply line to a turbo
craigieeb
Post Thu Apr 05, 2012 8:01 pm
Is it not type A?
im sure there basically the same as the M50/M52 oil filter housing...?
cypriot_boy_2k7
Post Thu Apr 05, 2012 8:25 pm
craigieeb wrote:Is it not type A?
I was looking at my mates they do look the same but don't want to chance just by look
fowler
Boost Junkie
Post Fri Apr 06, 2012 7:43 am
you can take a feed straight off the bottom of oil filter housing i have done it :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
cypriot_boy_2k7
Post Fri Apr 06, 2012 9:53 am
fowler wrote:you can take a feed straight off the bottom of oil filter housing i have done it :D
Any pics Fowler? From the pressure switch joint? I never knew you was a local zoner :)
