BMW E30 Alarm/security info needed
bhaza
Hi I have a BMW e30 325i Cab, Im learning that these cars are stolen often, any tips on why it is so easy, what I mean is should I leave factory alarm or should I get aftermarket alarm like a clifford or something? What precautions should one take to protect the motor?
Which alarm is on it at present? Is it the factory fit one with the separate magnetic key and barrel in the drivers door or does it have a a remote fob like most alarms?
If it has a remote fob then it will have been dealer/retro fitted and not factory fitted.
If its the separate key type then that is factory fit and i would be very surprised if it still works!
Most alarms that has been dealer/retro fitted will deter or stumble the average opportunist car thief but quite often is the case that E30's especially cabrios in London are stolen by people who know these cars and are stealing them to break for parts.
These are the sort of people you need to worry about as they will know ways to get round fitted alarms/imobilisers or in some cases they will just tow the car way with a truck!
To stop someone breaking in and driving away, Brianmoore suggests fitting a hidden switch on the live wire to the fuel pump and to ground so when switched as soon as someone cranks the engine it will blow the fuel pump fuse and continue to do so until the hidden switch is switched from ground.
This though will not stop the car from being towed away, you just have to be vigilant as to where and how you leave your car.
Sad but true but that's London for you!
bhaza
What do you think of clifford alarms, Im thinking of getting one fitted with the shock sensor, anti jack, microwave sensor, air horns as well and the bright blue leds
Dezzy
- CR24v it's a lifestyle
Most of the threads I've read, about car's going missing in the Capital, have been removed on the back of a low loaderbss325i wrote: These are the sort of people you need to worry about as they will know ways to get round fitted alarms/imobilisers or in some cases they will just tow the car way with a truck!
Clifford are a load of shite with to many gimics.bhaza wrote:What do you think of clifford alarms, Im thinking of getting one fitted with the shock sensor, anti jack, microwave sensor, air horns as well and the bright blue leds
Dezzy
I would have to agree with Baz on this one.bss325i wrote:Clifford are a load of shite with to many gimics.bhaza wrote:What do you think of clifford alarms, Im thinking of getting one fitted with the shock sensor, anti jack, microwave sensor, air horns as well and the bright blue leds
I have it on very good authority that Clifford Alarms aren't great and most who fit them are worse
sweep
As above and most cliffords are fitted very messy...wheel clamp?
kolee
A steering lock would deter most opportunist thieves as much (if not more than) a clifford alarm.
Anyone serious enough to really want to nick your motor wont be stopped by either.
Realistically you need to block your car in, even steering locks and parking with the wheels turned against the curb wont stop a low loader with a winch
It makes me want to cut the tow eyes off my car
Tracker would be a much better spend than a clifford or most immobilisers, as said above Brians immobiliser is much more effective than most you can buy off the shelf
bmw9818
id opt for the switch to the fuel pump, im gonna be installing that soon, if they manage to break in, id install an actual alarm, shock sensor etc, so it will alert you if anyone tries it, even if they tow it shock/tilt sensor should go off,
steering lock for visual deterrence,
then if all else fails a tracker hidden somewhere, probably your only failsafe, id try get some oem coded wiring and blend it in with the loom best i can so it doesnt look out of place,
Rather than fitting the siren in the engine bay you have much better chance of getting rid of the scum by fitting it inside the dash somewhere, 120 db at close range takes some persistence
Dezzy
Drivers front headrest?DanThe wrote:Rather than fitting the siren in the engine bay you have much better chance of getting rid of the scum by fitting it inside the dash somewhere, 120 db at close range takes some persistence
Behind the dash FTW, if it can be got at it can be pulled out
I just plug my garage door into the mains via a 80A circuit breaker, better to be safe rather than sorry
Idol
A switch would be better between one of the wires to the coil, if this circuit isn't made the coil wouldn't energise, thus no spark to the spark plugs. It would just turn over and not fire! The fuel pump one on the other hand, if you forgot you switched the switch you would always be blowing fuel pump fuses!
bhaza
ah thanks for that mate will be doing this over the weekend
thanks
thanks
If you did that and forgot the switch then you would be pumping fuel into the cylinders which could flood the engine.Idol wrote:A switch would be better between one of the wires to the coil, if this circuit isn't made the coil wouldn't energise, thus no spark to the spark plugs. It would just turn over and not fire! The fuel pump one on the other hand, if you forgot you switched the switch you would always be blowing fuel pump fuses!
Quicker to change a fuse than pull all the plugs out.
It's also very easy to put a live or earth to the coil but a lot harder to find the short to ground on the fuel pump live.
Idol
Got to disagree, as soon as its turned over a couple of times and not fired you realise that you havn't flicked the switch. It don't flood it either. If it was me, I would be putting fuses in all the time, as I've got a shite short term memory!
Fair enough, each to their own but the fact of the matter is that shorting the fuel pump live to ground is more secure than removing the live or ground from the coil.
90% of after market and all the OE immobilisers do interrupt the live feed to the coil, as Idol suggests, (and the 'on' signal to the ECU).
In the glovebox of my car, I have a metre length of wire with a croc. clip on each end. One clip on the coil + terminal, and the other on the battery or phantom battery + terminal, and the immobiliser is defeated. It's as simple as that!
Short out the fuel pump line, as I've previously suggested, and even if I know exactly what's happened, it will still take me several minutes to bypass. The average scumbag won't have a clue what's happened, and will not manage to start the engine.
