2nd lot of bbs caps stolen,need to know how......
lamby
Post Thu Apr 05, 2012 6:16 pm
as above put 2nd set on at weekend,went to hospital with my young un,came out all 4 gone.last ones nicked 150 mile from home so...what i want to know is how can i hold on a set from 5 stud wheels as i,m not replacing these again.plus any one buying some with mc1.2.3.4 inside let me know,c***s :x
Post Thu Apr 05, 2012 6:28 pm
You have to either fix them on with sealer or drill/tap the wheel and bolt them on
Id rather drive about without the caps if your using public carparks
adit
Post Thu Apr 05, 2012 6:34 pm
you will need to cut the plastic about on the back of the 5 series caps, but i have done this before and fitted them onto E30 x-spokes with a ring of silicone sealant (not anything more permanent though, for obvious reasons).
they look better than having no caps and there's not much chance of them being stolen.
or, remove them when leaving your out of sight.
what areas were they stolen from?
[quote="bss325i"]
lamby
i do,but 4yr old broke his elbow 2day,wife at work in e46 so car seats in back of cab,a.e for 2 hours which was nice,then out to this,would the drill tap not affect the balance,what sealer would be man enuff?
Steve-E30
East Sussex Hooligan
Post Thu Apr 05, 2012 6:35 pm
Check ebay in the area they were stolen
If you spot ant ask for a pic of the reverse of the caps
Hopefully catch the thiiving scumbag
Giggety Giggety Goo!!!
lamby
Post Thu Apr 05, 2012 6:39 pm
oh my throat throttlers are already checking the bay :evil:
lamby
Post Thu Apr 05, 2012 6:42 pm
@ adit,have removed all plastic from the back,and all though not exact will look better than nowt,south yorks taken from.ant rec on sealent?
Post Thu Apr 05, 2012 6:44 pm
Another option is to obtain a set of the much less valuable one piece plastic caps that were fitted to the E34. Chop off all the bits that stick out of the back, and glue them in place with silicon sealant.
adit
Post Thu Apr 05, 2012 6:45 pm
lamby wrote:...what sealer would be man enough?
just standard £1.99-a-tube clear silicone sealant
Brianmoooore wrote:Another option is to obtain a set of the much less valuable one piece plastic caps that were fitted to the E34. Chop off all the bits that stick out of the back, and glue them in place with silicon sealant.
as all already stated above Brian
:chuckle:
[quote="bss325i"]
lamby
Post Thu Apr 05, 2012 6:55 pm
cheers lads will get em on 2nite and put fish hooks through them :evil: that will hurt
Ajsingh
Post Thu Apr 05, 2012 9:32 pm
Take em off when your in public car parks, i do that
E30 Crazy!
George
Post Fri Apr 06, 2012 7:59 am
Steve-E30 wrote:Check ebay in the area they were stolen
Happened to a mate in Canterbury a few weeks back. Had them stolen and they were on ebay by the weekend! He recognised them as his own (owing to the extent of the wear/missing bits of the badge) and informed the police. They told him since he couldn't 'prove' they were his, nothing they could do. He ended up bidding on them...but lost.
Post Fri Apr 06, 2012 8:36 am
Could put your initials & postcode on the back of the caps in permanent marker and then photograph the caps next to your car ?
If they ever got pinched and then turn up on the bay they can be identified by this proof ?
Can't believe people still stoop so low as to steal centre caps.
Bloody scummers :evil:
Post Fri Apr 06, 2012 9:20 am
If you get onto your local police they will give you a security marker/UV ink pen, they usually hand these out when you inform them youve been burgled. That way, if you do recognise something and tell them its security marked they have no excuse but to check it out
**BANNED**
Post Fri Apr 06, 2012 10:38 am
Open invitation to come around and take the car and clear your property at the same time!
Be better to use car registration number?
Dezzy
CR24v it's a lifestyle
Post Fri Apr 06, 2012 6:55 pm
Or anything that you could use to identify them as yours.
Post Fri Apr 06, 2012 7:01 pm
Obvious markings are a daft idea, any thief is going to remove them or cover them up. A slight out of the ordinary mark and security pen is the way IMO
As long as centre caps are making the money on ebay they will continue to get stolen
Dezzy
Post Fri Apr 06, 2012 8:32 pm
DanThe wrote:Obvious markings are a daft idea, any thief is going to remove them or cover them up. A slight out of the ordinary mark and security pen is the way IMO
The only problem with a security pen marking is you'll never know the cap's are deffos yours.
If the seller has covered your marking you'll still be able to see that in the add.
I would not leave my E30 anywhere TBH. It isn't a daily though. I have a 2004 Leon TDI which has a new ding everytime I look at it. I can't even be bothered to replace it for that very reason. My work van does me proud
Post Fri Apr 06, 2012 8:56 pm
Same here, I use the van to go everywhere I need to, at least I know if it does have a new ding somewhere, i won't be too bothered.
lamby
Post Fri Apr 06, 2012 9:05 pm
i scratched my mark on them after the first set went,so they can,t be covered over.norm taken off but 4 yr old with bust elbow,18 month old trying to get out the car to A and E twas the last thing on my mind.still got free easter eggs for kiddies from nurses.jusy annoying,thought it might be the torque rippin them off as its a 320i se auto cab with A/C and car seats in.RAPID.am i clutching at straws
Post Fri Apr 06, 2012 10:18 pm
Thats why I said to put a smallish mark so you can recognise them, like cut a V somewhere or a grinder mark etc.
TBH id rather just take them off if I had to use car parks
Dezzy
Post Fri Apr 06, 2012 10:22 pm
I'd have to agree mate.
I'd rather just live up here. Our scum bags have set their sights higher than a few quid for some old sh1tters centercaps :D
lamby
Post Fri Apr 06, 2012 11:21 pm
thing is 60quid plus aint bad for 40 secs work,plus old shitter hope you mean me and not my car :mad:
Dezzy
Post Fri Apr 06, 2012 11:31 pm
lamby wrote:thing is 60quid plus aint bad for 40 secs work,plus old shitter hope you mean me and not my car :mad:
I meant your car sorry winkeye
Post Fri Apr 06, 2012 11:38 pm
I used a small drill to fit small countersunk self-tapping screws to mine. They never went missing, despite parking it out on the street. :)
lamby
Post Fri Apr 06, 2012 11:41 pm
cries into his hands in shame,was going to york drag but i,ll just get humiliated by a bus on the way. :(
Dezzy
Post Fri Apr 06, 2012 11:49 pm
lamby wrote:cries into his hands in shame,was going to york drag but i,ll just get humiliated by a bus on the way. :(
Why would you allow other people's opinions effect your fun? :mad:
