fitting oil temp and pressure gauge to m30b35 lump
wixsy
Post Mon Mar 26, 2012 5:37 pm
Hi, two things and i hope somebody can help, i want to fit aftermarket gauges to my e30 using this engine and i may well be a bit dim but i cant find a take off to enable me to fit a mechanical oil pressure or temp gauge. as its a track car i wanted to fit these and prefer the old fashioned mechanical ones to the electrical. Whilst trying to find one i took of the what i presume to be a pressure relieve thingy.. A plug with a spring behind it and a cylindrical tube on the end of that, will i have buggered anything up by doing that as i put it straight back and did it up as soon as poss.
So firstly have i buggered anything and secondly are there any take of points or do i have to go electronic with the gauges, thanks in advance regards Tony
Bristol_Jer
Post Mon Mar 26, 2012 7:02 pm
Good question, I've got the gauges to fit mine as well, hope someone knows the answer :)
Not sure on the part you removed though sorry
winx
Post Mon Apr 02, 2012 6:08 pm
The part you have removed sounds like the chain tensioner to me? Was it at the front of the engine? Hopefully the chain wont have slipped when you removed it otherwise the timing could have changed!
I used a t piece to take a feed from the oil pressure switch at the back of the head (on the right hand side when looking from the front of the car) for oil pressure. Temperature I took from the oil filter housing, but that has been swapped to one from an e28 so I can have an oil cooler.
wixsy
Post Tue Apr 03, 2012 8:54 pm
Hi Winx, could you please post a pic of where the oil pressure switch on the back of the head is and also what part the oil filterhousing is, is it an easy swap. i m a ford man really and a bit lost with these m30b35s.
winx
Post Tue Apr 03, 2012 10:45 pm
I'm the other side of the country to my car at the moment but one of the first images to come up on google shows the pressure sender:
And another shows a pressure sensor attached:
Can't find a picture of the oil filter housing I'm afraid.
leeparkes
Post Tue Apr 03, 2012 10:47 pm
You can see the sensor in this pic, at the back of the head just above number 6 inlet port.
Edit, beat me to it. :)
Bristol_Jer
Post Thu Apr 05, 2012 5:26 pm
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=30
Is this the e28 oil filter housing you used winx? Been looking on Realoem, and that one is from an e28 535i
Bristol_Jer
Post Thu Apr 05, 2012 5:46 pm
There are oil cooler adapters here, guess they could be tapped to fit a temp sensor?
http://www.thinkauto.com/takeoff.htm
winx
Post Sat Apr 07, 2012 10:21 pm
Bristol_Jer wrote: Is this the e28 oil filter housing you used winx? Been looking on Realoem, and that one is from an e28 535i
Yup that's it
wixsy
Post Sun Apr 08, 2012 4:39 pm
Cool,thanks chaps. Oil pressure out of the rear of the head, done. what is the stock oil pressure on these, hot and cold on tickover and about 3k when hot. Now need to get the oil filter housing. I want to run a mechanical oil temp gauge so does this housing have a take off for the sender or does it fit in one of the holes in it. God i wish i knew more about these. That what comes from being a ford man i guess :?
Anyways thanks again for the help, regards Tony
martijn76
Post Sun Apr 08, 2012 6:16 pm
I fitted a Y-piece with a temperature sender, needs less space:
Bristol_Jer
Post Mon Apr 09, 2012 10:37 am
Where did you buy the Y-piece adapter?
Bristol_Jer
Post Mon Apr 09, 2012 12:45 pm
Yup that's it
Is it a straight swap to fit to an e34 535i engine?
martijn76
Post Mon Apr 09, 2012 4:55 pm
Bristol_Jer wrote:Where did you buy the Y-piece adapter?
It's from Raid. I drilled the narrow side out so the temperature sensor would fit.
george_graves
Post Mon Apr 09, 2012 8:56 pm
Do you have a link to the "raid" web site? I'm not familiar with them.
M30B35 powered '89 e30 325is
martijn76
Post Thu Apr 12, 2012 7:50 am
I cannot find their website, but here's a link to the products:
http://www.tuning-rdi.de/index.php?cat= ... mente.html
martijn76
Post Wed Apr 18, 2012 4:10 pm
Theo
Post Sun Aug 26, 2012 11:42 am
I have an e34 m5 oil filter housing for sale with pressure & temperature sensors included - also comes with pipes - you just need the correct oil cooler.
