running lumpy when cold.. worse when warm.. intermittent fault getting worse
325i 1990
is ther any that can put it on a computer for diagnosis local to reading?
appreciate your help guys!!
running rough!!
three-two-five
Grrrmachine
- E30 Zone Wiki / Team Member
computer diagnostics???
Are you getting bad mpg, and is the idle wobbly or not? That would tell us whether it's a) an air leak or b) the blue temp sensor. It's usually one of those two. But don't throw money at the problem until you've done some basic tests, which are covered in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
three-two-five
cheers will look into above links and report back...
