Will BMW Mini wheels fit an E30 cab?
fastcarz464
Sat Nov 26, 2005 9:01 am
I have seen a set of rims i like but they are for a bmw mini, size are 18", 215/35/18, will they go staight on, or require spacers etc or not go on at all, my car is a 92 e30 cabriolet, cheers guys!
chu346
Sat Nov 26, 2005 10:06 am
IIRC the PCD is different, so they won't fit with or without spacers.
dasparkybad
Sat Nov 26, 2005 11:17 am
are you shure
my mate has mini cooper wheels on his astra van doesn't that have the same pcd as e30
Demlotcrew
Sat Nov 26, 2005 11:38 am
They will fit with spacers.
Andrew
chu346
Sat Nov 26, 2005 1:20 pm
Sorry its the center bore which is different
E30: 57.1mm
Mini: 56.1mm
fastcarz464
Sat Nov 26, 2005 7:17 pm
So will they fit then, where do i get the spacers from, how much do they cost and what type of spacers do i get, cheers.
Kos
Sat Nov 26, 2005 7:45 pm
10mm dedicated spacers and hub centric rings, longer wheel bolts all required
www.pukardesigns.com
IG Pukar.Designs
Lowm3
Sat Nov 26, 2005 7:52 pm
seen some vw's using them too 4 x 100 ..
but yep would need spacers... they do look good though.
