1.8 or 2.0 exhaust on m50 ?
BATTS91
if i was to use a 1.8 or exhaust system on my m50 does anyone think it would restrict it much ? or would using a 320 system that has a single pipe into rear box ? need to sort new exhaust out on a budget and dont want twin exit thanks
B15NAC
A 318 exhaust is way to small I would say! If you went single you would need 2.5 inch diameter at leased
BATTS91
thats what i have made for the mo 2" into 2.5" but its not as good as id like it to be thanks fella i thought it wouldnt be wise doing it
if there is any 2" pipe it's going to be held back.
+ a yard full of scrap turds
Use a 325 system minimum
BATTS91
i have 2" on the down pipes only i thought they were standard that size ?
