I finally got the head off my m20 and absolute mayhem was revealed. Piston is split in half, pieces of metal everywhere, water in the cylinder ( il put a pic up later )
I did some phoning/online work and its actually going to be way way cheaper to use my 320 motor and get it insured than expected so im going to just use that. Will i need to swap the gear box aswell or will the 2.5 gearbox be fine? Obviously il need to swap the ecu and so on....
cheers
Swapping my motor
verde
Raise hell praise Dale.
Grrrmachine
- E30 Zone Wiki / Team Member
The 325 gearbox will make the 320 really sluggish in first and second, so it's not really recommended; plus the 325 box has some resale value, unlike the 320.
Ideally you want to drop the lump and box in together; it's a massive ballache trying to get the box on with the engine in situ.
But done properly, you should end up with a nice clean cruiser out of the two cars. Do you know what diff you've got fitted at the moment? Big-case 325, or the original 316 one?
verde
alright thanks man. il just put the 320 box and lump in as a whole. unsure of the dif, i think its like a 318 diff on it ( the acceleration from that with the 2.5 was absolutely insane ) im not sure, i could leave it on or i could take the 320 one off and use that for more even gearing.
hopefully we get the box and lump sitting in the car today and then its just a case of going round putting on hoses and bolts.
its the ECU/computer bit thats worrying me, what bits go where and what needs doing
verde
my dad holding what used to be a piston head.
good workverde wrote:my dad holding what used to be a piston head.
+ a yard full of scrap turds
verde
Iv never seen a piston in such a mess. I reckon the first time it blew its put a hairline crack in it and this time it just exploded
Grrrmachine
I think you're probably right. The first damage was probably done the first time it snapped a rocker arm, and your "mate" saw the damaged piston when he took the head off - that's why he didn't do a proper job putting the engine back together.
Anyway, to get you moving; a quick way to see what diff you've got is to count the bolts on the backplate, since you can do this while it's still fitted. If you've got six bolts, it's a small-case diff and is therefore suitable for the 4-pots and the 320, and if it's got eight bolts it's a medium-case diff which are normally for the 325.
Don't worry about the loom and ECU and stuff. If both the 325 and 320 engines are facelift ones, then you can keep the engine loom in place and just plug the 320 ECU in where the 325 ECU used to be.
verde
i mean i saw the pistons when he had the head off and they looked fine, but fuck knows.
il go check my new one then, its either a 316/8 one so it should be fine with the 320. ideal that i dont need to piss around with the engine loom. thanks alot for the help grrr. hopefully later on i shall be uploading a picture/video of my new engine purring away in my new car
Cypriotgeeza
must have been exciting when that happened
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
leeparkes
I blew a hole in an M20 piston
Never even seen one split in half.
verde
haha holy fuck lee. yeah this is mad
we just did the most redneck engine lift ever, we dont have a hoist so we used ingenuity/stupidity and the beams in the old school part of my house. il get pictures. but the 2 litre is out. just need to get the remainder out the 2.5 and drop the new one in.
verde
redneck engine crane. definitely renting or borrowing a proper one for putting it in the new car. ( u might get a phone if u see this james )
