Touring dog guard mounts.
Sanchez
Fri Mar 30, 2012 2:26 pm
Hi All
Ive a touring roller dog blind and the mounts but where in the roof to they fix too?
Anyone have a pic to show me the rough location.
cheers.
Fri Mar 30, 2012 2:33 pm
Don't think you can do this without removing the headlining as if you cut in the wrong place it will look awful ! :cry:
With the headlining out the area to cut for the mounts is marked on the reverse side.
The captive nuts are already in place in the roof structure - you need to cut the headlining in exactly the right position or it just won't work.
If you can drop the headlining down at the back you should just be able to see where the captive nuts are, but I doubt it will drop enough for you to get a blade in to cut it in the right place - you might be able to mark it in some way though.
rover-2000
Fri Mar 30, 2012 4:10 pm
Best bet is to find someone local who already has the mounts and measure carefully. Where are you?
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Sanchez
Fri Mar 30, 2012 6:15 pm
rover-2000 wrote:Best bet is to find someone local who already has the mounts and measure carefully. Where are you?
no one near me has one. My dad wants his fitted as well but ill do mine first.
Does the mount fit near the C pillar? Does the guard go straight up or angled?
rover-2000
Fri Mar 30, 2012 6:19 pm
Yes, but where are you? Mine has one.....
It's roughly 6 inches back from the C pillar.
Kind regards
John
1989 320i Touring
Sanchez
Fri Mar 30, 2012 6:42 pm
Edinburgh.
Do you have pics where the bracket in the headlining is?
rover-2000
Fri Mar 30, 2012 6:51 pm
Nowhere near me then ! :D
Will try to take a pic tomorrow.
Kind regards
John
1989 320i Touring
Cloggy Saint
Fri Mar 30, 2012 6:56 pm
Any use?
Sanchez
Fri Mar 30, 2012 6:58 pm
cheers Jeroen, that looks like it goes straight up.
Thats tomorrows job sorted then.
Fri Mar 30, 2012 7:01 pm
Here ya go :
Looks like the mounts are exactly mid-way along the back window - I'd still be dropping the headlining down to try and cut it through from the factory markings on the back though.
HTH
Sanchez
Fri Mar 30, 2012 8:56 pm
Cheers Rob, your headlinings looking great, ive got the material just need the time, and lots of it by reading yours and others 'how to' guides.
adit
Sat Mar 31, 2012 8:39 am
yes, the net is vertical. if you follow the photos above, you may be able to feel the screw holes through the headlining
[quote="bss325i"]
TPS
Sat Mar 31, 2012 8:50 am
I need to do my 2, Thanks for this, I also need to buy a Dog, to complete the look.
