Side indicator
biggill
Post Wed Mar 28, 2012 11:01 am
I have just brought a set of clear side repeaters, went to swap them over only to find the bulb holder is to small i was told about this before that you may have to adjust the bulb holder is that true, has anyone come across this before how did you overcome it?
My car is a pre facelift cabby, the lenses are supposedly for a pre facelift.
Cheers Gill
jimf
Post Wed Mar 28, 2012 7:52 pm
I have just had to 'adapt' the ones I bought. The holders on the new indicator was too long and the bulb bit on the car wouldn't fit. If this is your issue too then this is what I have done.
I hacksawed the holder part of the indicator in half then rolled back the rubber that covers the bulb and wire. Ten stuck the bulb in place, rolled the rubber forward and that seems to be holding it in place.
biggill
Post Wed Mar 28, 2012 8:44 pm
So there is no real fix just a bodge job lol, thank's for your info jim will give it a go.
Gill
