1988 316 1.8 auto m10 belt or chain
teatime39
Post Tue Mar 27, 2012 6:59 pm
Hi guys , I've looked through tons of old posts looked on the net to find out if i have a timing belt or chain , i feel a bit stupid not knowing but how can i tell one way or the other
johnl320
Post Tue Mar 27, 2012 7:03 pm
Chain
teatime39
Post Tue Mar 27, 2012 7:05 pm
thank you John , what is the life of the chain as the car has 150,000 on the clock
Andyboy
Alpina Colada
Post Tue Mar 27, 2012 7:26 pm
The chain doesn't really wear, but the cam sprocket does. If it sounds rattly, it probably needs a new one.
teatime39
Post Tue Mar 27, 2012 7:33 pm
is that an easy job , my knowledge of enngines is limited but am quite able to do the work if following instructions , are special tools or equipment needed?
johnl320
Post Tue Mar 27, 2012 9:38 pm
If its quiet I would leave it alone, unless you plan on keeping the car for a very long time
teatime39
Post Tue Mar 27, 2012 9:55 pm
I will be keeping the car for sure , it does sound a little tappy but to be honest there are other things that need doing , weber carb refurb an oil leak among other little bits ,
