Bigger brakes
Mike_e30_325i
Post Mon Mar 26, 2012 8:04 pm
Hi I am looking at upgrading my front brakes was just wounding what options I've got as in new big brake kit or what other brakes fit and are a good upgrade
N00b
Post Mon Mar 26, 2012 8:15 pm
Mike_e30_325i wrote:Hi I am looking at upgrading my front brakes was just wounding what options I've got as in new big brake kit or what other brakes fit and are a good upgrade
The first decision is what diameter wheels do you plan on using?
turk
Post Mon Mar 26, 2012 8:19 pm
I have a set of Mazda rx7 callipers, bracket to fit straight to e30, and redstuff pads. I am running Lenso 16's with spacer.
pm me if you're interested and ill get some pics.
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Mike_e30_325i
Post Mon Mar 26, 2012 8:25 pm
At the mo I've got 14" bbs wheels but I will be having 15" on soon not sure what size I need, I have turboed the bm so would like to stop a tad quicker lol
turk
Post Mon Mar 26, 2012 8:29 pm
I would say 15 would be very tight. 16's to be safe!
Sump Baffles
TrackDays
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Mar 26, 2012 8:34 pm
Mike_e30_325i
Post Mon Mar 26, 2012 8:49 pm
Would new driled and Groved disks all round with some decent pads and good ridge hoses be enougth
N00b
Post Mon Mar 26, 2012 9:00 pm
Mike_e30_325i wrote:Would new driled and Groved disks all round with some decent pads and good ridge hoses be enougth
As I understand it, caliper piston surface area is more important than fitting uprated disks. The hoses are a given though, regardless of how far you go with your brake upgrade.
Mike_e30_325i
Post Mon Mar 26, 2012 9:12 pm
Ok so some hoses and 4 pots would be way forward, just depends what I can get behind me wheels, the Rx 7 calipers seam common can they be used up standerd disks or would they have to go bigger
fuzzy
He who sleeps with "Gingers"
Post Mon Mar 26, 2012 9:13 pm
depends on how much turbod power you have and how hard you drive it. iirc uprated discs. pads and fluid with the goodridge hoses was fine for my erratic driving style but prolonged abuse and you could feel them starting to fade.
N00b
Post Mon Mar 26, 2012 9:16 pm
fuzzy wrote:depends on how much turbod power you have and how hard you drive it. iirc uprated discs. pads and fluid with the goodridge hoses was fine for my erratic driving style but prolonged abuse and you could feel them starting to fade.
Agreed. Just saying you've "turboed" it doesn't give enough info. If you're making anything like silly power than you need good anchors, and TBH I'd be considering 16" wheels unless you're running a low boost engine.
Mike_e30_325i
Post Mon Mar 26, 2012 9:22 pm
Ok maybe just updated should do for now as don't brake from high speed much would be fine
Mike_e30_325i
Post Mon Mar 26, 2012 9:24 pm
Running 10psi, hasn't been fully set up yet so unsure on power
fuzzy
Post Mon Mar 26, 2012 9:45 pm
10psi on a relatively otherwise standard 2.5?
Mike_e30_325i
Post Mon Mar 26, 2012 9:49 pm
Yeah that's it
keri-WMS
Post Mon Mar 26, 2012 10:33 pm
http://www.e30zone.net/e30zonewiki/inde ... e_Upgrades < I wrote most of this, from an upgrade point of view - have a good read to help make sure you get the bias right etc.
280mm/4 pots are popular as they fit in the 15" BBS, which are ideal for trackdays etc - 298.5mm fits in 16's like the Hartge (but the 16" Alpina needs 280mm due to the daft poke shape).
