Hi guys, does anyone know how much oil I will need to fill a gearbox and LSD on my sport?
Gearbox and diff capacity
- Brianmoooore
1.25 litres and 1.7 litres respectively.
Grrrmachine
- E30 Zone Wiki / Team Member
If you put "Oil" into the Wiki you get the answer immediately
- E30 Zone Meets/Events Team
- Contact:
Make sure you undo the Fill bolt first, if you undo the drain plug first, you might get stuch if the fill one doesn't budge.
just turn the car upside down ?Rav335uk wrote:Make sure you undo the Fill bolt first, if you undo the drain plug first, you might get stuch if the fill one doesn't budge.
- Contact:
e30topless wrote:just turn the car upside down ?Rav335uk wrote:Make sure you undo the Fill bolt first, if you undo the drain plug first, you might get stuch if the fill one doesn't budge.
