red black wire mod
BATTS91
right so ive just looked on the wiki for red and black wite mod for central locking , the problem is it never worked whe. i ot tw car i got a new relay it worked a few times and now only works when it wants so far as ive seen this could resolve my problem ,also i have a coupe so am i right in thinking that there should be 2 reds and 2 blacks but do i connect the 2 reds together seperate from the 2 blacks right ?
BenHar
Can you repeat that in English, please.
Ben
Ben
BATTS91
my central lockin intermitantly works wooud te mod possibly do the trick and is there just one red and one black put them together or 2 reds 2 blacks and put red to red black to black , clearer soz i do go on somtimes it makes sense to me lol
BenHar
Hmm, perhaps you could try Welsh?
Ben
Ben
BATTS91
i clearly understand lol ,what wires do i connect for this central locking mod the black and red together yes ?
thanks
thanks
Grrrmachine
- E30 Zone Wiki / Team Member
I don't really see how the Wiki can be any clearer. Once you get to the wires, all will become clear.
You do drag your problems out a bit, don't you
BATTS91
lol well i havent had. look wanted to be abit clearer before i take speaker ect out again but if you say it will make sense when i look so be it thanks
Grrrmachine
To assist, the door plugs are called C404 and C405 and are listed in the Wiki:
http://www.e30zone.net/e30zonewiki/index.php/C40x
It's the wires to pins 3 and 15 of C405 that you'll be linking.
grantfk10
- E30 Zone Meets/Events Team
Have you actually located said wires?
BATTS91
ok so ive got c405 in my hand (passenger side as stated in wiki pin 3 in blue and black and nothing at pin 15 ? no red and black wire ?
Send brianmoooore a pm, he can talk you through this in minutes
BenHar
That's your problem. You should be on the drivers side.BATTS91 wrote:passenger side
Ben
Grrrmachine
If Pin 3 is blue and black, then you're mixing 1 and 3. That would make sense if you have nothing at 15 (opposite position is pin 8, which should be empty.)BATTS91 wrote:ok so ive got c405 in my hand (passenger side as stated in wiki pin 3 in blue and black and nothing at pin 15 ? no red and black wire ?
But still, THIS is the Wiki guide you should be following:
http://www.e30zone.net/e30zonewiki/inde ... re_Problem
I don't think Brian's checked his PM since 2008.DanThe wrote:Send brianmoooore a pm, he can talk you through this in minutes
BATTS91
thanks ill have another look tomorrow
jonny323i
Its defo drivers side wiring there are 2 blackwires with a red stripe or the other way round i can remember you need to cut them fom the back of the plug that goes into the door pillar and join them together!!
I sturggled to understand the wiki myself mate when i did mine! The wires send a live loop into the door wiring and when the pins corrode the circuit is broken as i was told and now understand so you are eliminating the loop into the door and cutting it short.
Touring for life
BATTS91
cheers bud all done now locking works well
Green
Just to query, my central locking is a little funny (I know this in turn should also be in tech help but alas a topic is here already)... I can lock the door at the drivers door but I cannot unlock it. The can be unlocked from the boot, but it cannot be locked from it... would this wire mod resolve this?
No, but do the mod. anyway. It's a preventative measure, not just a cure for an existing fault.
Your problem is down to a combination of wear on the L shaped alloy piece on the back of the lock barrel, small amounts of general wear elsewhere in the linkage, and probably a dire need for lubrication.
Try adjusting the lock motor slightly in its slotted mounts. It's just hidden by the rear edge of the door card, about half way down.
