Dismantling wing mirrors
Black_Potato
Post Thu Mar 22, 2012 10:00 pm
Hi,
I need to take some wing mirrors appart to have them painted and I;m wondering how best to do it ?
Does the back prise off, or maybe you have to remove the mirror?
TIA
Richard
3x S14 Rightness....
spook
League two here we come !!!
Post Thu Mar 22, 2012 10:15 pm
Theres a little screw on the underside of the mirror body, give it a little turn and the glass should come out.
Post Thu Mar 22, 2012 11:35 pm
spook wrote:Theres a little screw on the underside of the mirror body, give it a little turn and the glass should come out.
There's no 'screw' as such. The glass is removed by rotating a large plastic ring glued to the back of the glass, and to enable this to be done, there's a small hole on the underside of the mirror and a few teeth on the ring. The idea is to push a small screwdriver through the hole, engage the tip with the teeth, and lever the ring around to the point where it unlocks and the glass comes out.
I find an easier way is to tilt the glass up as far as it will go, then push the small screwdriver under the bottom edge of the glass and into the teeth, which you should be just able to see.
Black_Potato
Post Fri Mar 23, 2012 9:43 pm
cheers guys, will have a butchers tomorrow.
