Is this an MOT failure or not..?!
Jungian64
Post Thu Mar 22, 2012 5:46 pm
The touring is up for its MOT next week, so had a poke around...and found this behind the rear wheel - Iam pretty sure its the sleeve that goes around the fuel line from the filler to the tank - so is this a failure or not? and if it is, what can be done about it..?!!
Thanks.
Post Thu Mar 22, 2012 7:11 pm
Won't be a fail as long as the hole is confined to the removable cover. A hole in the inner wing itself will be a fail if the hole is within 300mm of a suspension mounting point.
Jungian64
Post Thu Mar 22, 2012 8:28 pm
Blimey..theres a removable cover under all that!
Post Thu Mar 22, 2012 8:29 pm
Jungian64 wrote:Blimey..theres a removable cover under all that!
Not very much of it in your case, I fear.
Jungian64
Post Thu Mar 22, 2012 8:37 pm
I fear, you're right!
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Mar 22, 2012 9:38 pm
Mine went exactly the same way:
The cover plate is held on with four plastic nuts (M8, IIRC), and one end pokes into the bodywork closest to the tank.
You can pick up new ones for a reasonable price, or even used ones if you're a penny pincher. If you're nimble, you don't even have to take the wheel off to swap it over.
Jungian64
Post Fri Mar 23, 2012 2:21 pm
Nice one!
Your inner wing looks considerabley cleaner than my cow crud encrusted one!
Thanks for the tip off.
aimlessrock
Post Fri Mar 23, 2012 7:42 pm
Mate, the cabby's have the same set up, i replaced mine few months ago, its a just a bolt on cover, the part was about £40.00 plus vat from memory from the main dealers
E30 320i Convertible (1989)
190 Mercedes (1988)
