Overheating, Rad stone cold, diagnosis anyone?
(overheating in this weather !!)
I would bleed it straight away with a stack of anti-freeze ready to fill the cooling system
Jose
Jose
- Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
Cool, I got one recently but haven't fitted it yet, hopefully get it sorted before tomorrow's meet.TOURINGDADDY wrote:sounds like the thermo mate id change that then bleed
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness
There is:
26th Lakeside
27th Epping, (www.Beemerforum.co.uk)
28th Ace Cafe
Then Donnington 3rd Dec with Dave touring
Then 11th Dec Rolling Road in Portsmouth
Few!!
Don't think i'll be able to go Donny but will be at the rest
26th Lakeside
28th Ace Cafe
Few!!
In Thetford, Norfolk/Suffolk styley.TOURINGDADDY wrote:tomorrows meet? u not comming down for the rolling road day on the 11th dec in portsmouth
I'll be working in germany then unfortunately. Bit of a trek to see how fit my car is.
lets keep on topic please, and get joe's touring back and healthy!
joe, i'd drain the coolant out and take off the pipes for the radiator 1 AT A TIME (so you dont get confused)
then i'd clean them all out so they were sparkly, and put a hose into the radiator at a decent pressure to flush out the fins (not too hard though!)
flush the hose from top to bottom, and if possible, bottom to top, to really free up any crud.
then take out the thermostat and flush out the block, again til its running clean.
fit a new thermostat and fix the system back up then refill and bleed!.
feel free to PM me your email addy and i can send a detailed instruction set to you..
- tourer-dan
Do the job properly, first time. Follow 320touring's advice and give the complete cooling system an overhaul.
The block drain plug is under the exhaust manifold at cyl.5. Buy a new plug and washer from the dealers as they dissolve with age. (you'll get change from Ԛ£3) don't forget the thermostat O ring too (should come with the new 'stat) And if you push the heater hose onto the stat housing too far it will leak!!
Good luck
Good luck
Here you go fella.................DaveD wrote:whats at donnington on the 3rd dec????????????
Track day 3rd Dec
and remember to have your heater set to maximum when you fill up and start it
well said!E30BeemerLad wrote:and remember to have your heater set to maximum when you fill up and start it
all inc in the guide I sent him, fingers crossed it works
