M62 Vs S62 oil pressure, Vanos in particular!
turk
Post Tue Mar 20, 2012 7:04 pm
Hi all,
I need to know the operating pressure differences if any, between the M62 and S62oil pumps.
My thought train is the m62 has single vanos' and the S62 has dual.
I will be fitting the S62 with an X5 sump and hopefully oil pump. I just need to know it will feed sufficient oil and pressure to the engine and the vanos.
I have checked everywhere I can think including BMW. I can't find a manufacturer of either pump so can't even call them direct.
Any help appreciated.
turk
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
davethegoat
Post Wed Mar 21, 2012 1:58 am
When are you going to start a build thread Turk?!! winkeye
Are the pumps interchangable?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=30
There's a fair difference in drive gear size...
turk
Post Wed Mar 21, 2012 8:32 am
Thread will be up soon. Just need to find some time to witte it all.
The pump should fit straight on as long as the surrounding parts ie sump pipes etc are used too.
I've just had confirmation they're the same volumed pumps too. The Vanos has its own pump do that's not an issue.
Sump Baffles
TrackDays
Post Wed Mar 21, 2012 8:36 am
turk wrote:The Vanos has its own pump do that's not an issue.
Was just about to say :D
turk
Post Wed Mar 21, 2012 3:37 pm
Sump Baffles
TrackDays
davethegoat
Post Wed Mar 21, 2012 10:52 pm
turk wrote:heres the thread on R3V so far.
http://www.r3vlimited.com/board/showthread.php?t=235274
I just had a read.... :mad:
My engine swap seems a lot more straightforward all of a sudden! Cheers!! :D
Sorry for the un-informed post BTW. It was meant as more of a question than it came across as! :o: :)
Having owned a couple of 4WD cars, I'll be following with interest. :D
Cheers. Dave. :D
