IVE CHECK THE OBVIOUS, FUSES,BULBS CONNECTIONS EXTRA BUT CANT WORK OUT WHY THEY DONT WORK. MR HAYNES AINT TO HELPFULL EITHER.
CAN ANYONE HELP ME, IM GETTING REALLY PISSED OFF POEPLE RELLING ME THEY DONT WORK.
Easier than crawling under the car to do this, is to lift up the gearlever gaiter, and to find a white two pin plug abnd socket down by the right hand side of the base of the gearlever.Jamesb318is wrote:Have you checked the switch on the g/box? it will be on the offside (i think) of the box, a screwed in 17mm nut with a connector+wire from it.
Unplug the connector, and short the wiring (not the switch), with a small piece of wire, if the lights come on, bingo new switch needed.
