Bump-stops
PeteE30Tourer
Post Wed Mar 14, 2012 7:24 am
I believe it's worthwhile changing the bump-stops when changing the springs front and rear, but having done some searching through previous threads on here on this subject, I'm confused as to what type I need. Am I right in thinking there are different types depending on what shocks you have? I had Bilsten B4's (I think) fitted last year, so do I need specific bump-stops to match these? I'm fitting Eibach springs with a 30mm drop, so I gather I need shorter bump-stops - someone mentioned E36 ones??
Can someone clear this up for me please???
Back behind an M20, but now I can hear it better.
Post Wed Mar 14, 2012 7:27 am
You can get Bilstein ones - did you have new ones and the plastic concertina covers when you had your dampers fitted ?
PeteE30Tourer
Post Wed Mar 14, 2012 12:40 pm
capri_rob wrote:You can get Bilstein ones - did you have new ones and the plastic concertina covers when you had your dampers fitted ?
To be honest, I cant remember as I didn't do it myself. I bought the Bilstens from ECP and I vaguely remember they came with fittings of some sort - never opened the boxes to find out what though.
Post Wed Mar 14, 2012 3:19 pm
You would have had to order them separately so in that case its likely that the originals have been re-used or there are none fitted at all.
Get your head under the arch and have a look :wink:
PeteE30Tourer
Post Thu Mar 15, 2012 9:24 pm
Had a look at lunchtime - all I can see inside the spring is the shiny centre shaft of the shock - no cover on it or anything.
