Hi Guys,
I'm doing to 5 stud conversion using the 'evo' set up up-front and the 'ti' set up on the rear.
I'm going to be changing the brake pipes to the braided ones and my question is what set to i buy. The e30 set up or do i have to mix and match the evo and ti ones?
Thanks,
Bhups
Brake Pipes
bhups
Thanks for that mate. Also i've seen 4 line and 6 line applications?
Assuming the car has rear disks and ABS you will need the 6 line braided kit.
ABS or otherwise has nothing to do with things whatsoever. It's discs that require the six line kit, and assuming no one has gone to the trouble of fitting ti rear arms and used the drum brake version, it's the six line kit that is needed.capri_rob wrote:Assuming the car has rear disks and ABS you will need the 6 line braided kit.
