Exhaust Manifolds (325i)
kiesh
Anyone what the standard exhaust manifolds on a 1990 325i engine were like? were they tubular or the normal cast iron crappy ones!? any pictures anywhere? also were the throttle bodies on a 325 any different to the ones on a 320? ive been told fitting 325 throttle bodies to a 320 makes a big difference to performance.... not sure whether i believe it!
E30Mark
325i come with normal cast iron manifold.
Do a search on the 325 / 320 throttle body conversions. Some people say the car feels much better, but someone? dynoed there car after the conversion and it was making less power than a stock 320... but they did not dyno the car before putting the 325 TB on it.
PM for details
PM for details
kiesh
Ok mate cheers, good to know
kiesh
err. yeah sorry for double posting there, not sure how i did that...? thanks fo the info guys, and the picture (from the other post!) any idea how much some tubular maniflods for a 325i are worth, and whether they would fit the 2.0 litre engine? presumably id need the mid section and tail pipe too?
DaveD
- E30Zone Wiki Specialist
as far as i know all the manifolds where cast. 6 branch for the three peice system are Ԛ£400 from the shop. If its for a 2 piece system Im intersted
dazleeds
- old skool raver
325 tb makes a definate difference i did it to mine and the car pulled so much better after also if you add a chip from ant you will greatly improve the drivability of any 320i
i have also just got a 6branch manifold but havent fitted it yet as im doing an engine change soon so will fit it then
i would def say do tb and get a chip and i think youll be pleased with the results
Daz
Daz
www.oldskoolfantasy.co.uk
kiesh
ok, whos ant and how much are his chips!?
E30Mark
Visit the zone shop, you'll find all sorts to spend your hard earned cash on...
Use the link at the top of the page or click here :- ZONE SHOP
PM for details
PM for details
kiesh
check out this listing on e-bay for your 2 piece tubular manifolds:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
jesmond
Won't you also need to grind out your inlet manifold to marry up to the bigger TB from the 325?
oze30
will the 6 branch fit a 2.7?
