Stud pattern on an F reg and H Reg cab
v70rs
Post Sat Mar 10, 2012 10:17 pm
Hi guys
I'm slightly perplexed- I bought a set of RH toplines that came off an F Reg cabbie to fit my H Reg cabbie, except the stud diameters are different- is this the case?
leeparkes
Post Sat Mar 10, 2012 10:22 pm
E30 is 4x100 with 57.1 centre bore.
Sounds strange. :?
mrLEE30
Post Sun Mar 11, 2012 4:21 am
i am also stumped, the E30 does not have any studs!
v70rs
Post Sun Mar 11, 2012 8:55 pm
Ok, bolts. That's for the pedants. The point being, there's a stud mismatch. Any advice?
jmc330i
Post Sun Mar 11, 2012 9:08 pm
What exactly is the mismatch? The bolt/stud spacing between the cars or the wheels and your car?
James
'91 325i Sport
'93 318i touring 16v
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Mar 11, 2012 9:11 pm
Have you got proof the wheels came off an E30 (i.e, did you seem them fitted), or did the seller just say "off an H reg"
Because all E30s should have exactly the same bolt pattern, unless the owner has done a 5-bolt swap to the entire setup.
v70rs
Post Sun Mar 11, 2012 10:01 pm
Only two bolts align: the other two are out. Only a photo of them being on his e30. All very confusing!
I thought the diameter may have changed. Mine's the H Reg, his was the F Reg.
kam-325i
Post Sun Mar 11, 2012 10:14 pm
v70rs wrote:Only two bolts align: the other two are out. Only a photo of them being on his e30. All very confusing!
All E30's are 4X100, except M3, which is 5Xsomething...
Sanchez
Post Sun Mar 11, 2012 10:19 pm
5*120
jmc330i
From the info I would say the wheels aren't 4x100. I've fitted some 4x98 wheels to an E30, they looked to fit ok but I wouldn't drive it very far!
It would be difficult to tell from a photo :?
Sounds like these aren't E30 wheels :( maybe 4x108??
James
'91 325i Sport
Sanchez
Post Sun Mar 11, 2012 10:20 pm
Dont suppose you have that pic for us to see and help.
dips346
London Meets Main Man
guessing you have brought 4x108
leeparkes
Post Sun Mar 11, 2012 10:44 pm
The stud pattern should be stamped on the rim somewhere.
