Factory fitted but not connected!
manni7rehal
Post Sat Mar 10, 2012 5:26 pm
Hi
all,
I am abou tto pass some rca cable from the head uni to the rear when I found a white connector not connected under the gear surround, as shown in the picture, can some help, what is it used for?
thanks
Manni
TPS
Post Sat Mar 10, 2012 5:29 pm
Its the Rear Electric Window Plug?
manni7rehal
Post Sat Mar 10, 2012 5:48 pm
Hi TPS,
there is only one plug and two windows, but there is no other plug
thanks
Manni
Post Sat Mar 10, 2012 6:35 pm
White connector hanging out the side of the console on the second pic. is one of the switch sockets for rear electric windows.
There will be a second one there for the other side, plus a two pin socket for the rear window isolator switch, unless someone has been busy with the side cutters.
manni7rehal
Post Sat Mar 10, 2012 7:58 pm
Hi
Brian,
Many thanks for your reply, can I fit change the rear wind up to electrics?, is it easy?
Manni
jonny323i
Post Sat Mar 10, 2012 8:22 pm
yes very simple you just need the looms for the rear doors, electric window mechanisms, 2 window switches and the cut off switch
Touring for life
Post Sat Mar 10, 2012 9:26 pm
99.999% the looms are already in the doors, motors and switches is all they usually need!
TPS
Post Sat Mar 10, 2012 9:34 pm
I've done this conversion in a couple of E30s I've had, Its very easy.
manni7rehal
Post Sun Mar 11, 2012 11:05 am
Hi
ALl, Thanks, I will check if the looms are in the doors, they would need to be connected to the connectors near the gear stick housing. so the motor will connect onto the current mechanism? and that just leaves the swicthes.
Please can you guys confirm this.. many thanks
Manni
toby
Post Sun Mar 11, 2012 11:44 am
The whole regulator for the electric windows is different. In very basic terms - you remove the manual regulator and fit the electric one. If the loom is there, you just plug it in using the plugs already in the door. Then add switches to the centre console and to the rear door cards.
If you do a search you may find a photo guide on how to do it. There isn't one in the wiki as far as I can see.
You should be able to pick up a rear conversion kit on here reasonably cheaply. When you see the parts in a picture it is more obvious what you have to do.
manni7rehal
Post Sun Mar 11, 2012 12:32 pm
Thanks Toby, I am just thinking is it really worth having the rear eletric windows?
Post Sun Mar 11, 2012 12:41 pm
manni7rehal wrote:Thanks Toby, I am just thinking is it really worth having the rear eletric windows?
No, its much more worthwhile to get out of the car or climb over the seats to wind the windows down :)
manni7rehal
Post Sun Mar 11, 2012 1:20 pm
cheers mate, lol
Post Sun Mar 11, 2012 5:04 pm
manni7rehal wrote:Hi
Manni
All E30s with a sensible number of doors have the rear window loom fitted at least as far as a socket inside the B pillars, where the loom for each rear door plugs in. All rear door looms have the central locking wiring, but only some have the wiring for the windows as well.
If you want to fit rear electric windows, and already have the full loom, it's just a matter of plugging in the switches and the motor. If you only have the part door looms, you will need to change them for the full ones.
manni7rehal
Post Sun Mar 11, 2012 6:53 pm
Hi Brian, many thanks.
I will have a look and report back.
thanks
Manni
manni7rehal
Post Mon Mar 12, 2012 4:49 pm
Hi
ALl this is what i have as shown below, the plug goeas as far as the b pillar.
So I would need the motor and the loom back to the plug, is that it, what about the window mechanism?, is this easy to fit?
Manni
Post Mon Mar 12, 2012 6:12 pm
You can clearly see in the first pic. that the body part of the loom has several more pins than the door loom, so you are one of the unfortunate ones that will need to change the door looms.
Actually fitting the rear electric window mechanism is just removing six bolts, changing the manual for the electric unit, and refitting the six bolts.
manni7rehal
Post Tue Mar 13, 2012 8:37 pm
Hi Brian,
Many thanks
Manni
