316i carb model - rev counter winds right round the clock
Jones
Post Sat Mar 10, 2012 12:06 am
Hi, I took my E30 for its mot today it failed on emissions as it was running dog rough (turns out to be massive air leak) so got that sorted hopefully get it back in soon and passed.
Whilst I was at the Garage, the owner who has really looked after me car wise recently had another E30 in (a chromie 316 carb moel - M10?) its got a fault with the rev counter whbich winds itself right round the clock, and its only done this since a battery change, the owner of the garage is a bit baffalled as to what it could be. I am going to take him up some spare clocks I have out of a 1987 325i I scrapped, so he can swap them round I believe you have to swap the chips round in the clocks??
and any idea as to what the fault could be?? any help would be much appreciated Regds Jonesy :)
1994 E34 525i sport - Sold
1991 E30 316i LUX 2 dr - soon to be 318is
SDM
Formerly WhiteM3
Post Sat Mar 10, 2012 12:09 am
if your rev counter winds round your cock your very well endowed.
bimmaman
Post Sat Mar 10, 2012 12:10 am
The title of this thread actually made me laugh out loud :)
Jones
Post Sat Mar 10, 2012 12:14 am
LMFAO! woops :o: well at least it made you laugh.
Post Sat Mar 10, 2012 12:16 am
Yes, you'll need to swap the coding plugs on the instrument cluster, as there are different ones for four and six-pot models.
As for the over-reading rev-counter, probably a loose connection or could be failing SI board batteries (two AA Ni-Cd cells that can be replaced, but you need ones with solder tags, or swap the ones off the old batteries).
Jones
Post Sat Mar 10, 2012 12:27 am
Speedtouch wrote:Yes, you'll need to swap the coding plugs on the instrument cluster, as there are different ones for four and six-pot models.
Thanks thats brilliant. I was thinking clocks and it only goes to a sensor, so not alot to go wrong.
Post Sat Mar 10, 2012 10:13 am
These particular symptoms are a new one to me, but SI board batteries are the first place I'd look, especially as the problem occurred after they had been left without a charging current while the main car battery was changed.
