What are everyones opinions on the best quality OEM front wheel bearings? I'm thinking possibly the SNR ones from ECP, but are there any others that would be recommended?
http://www.eurocarparts.com/ecp/c/BMW_3 ... 745&000370
Best OEM wheel bearings (without going genuine)
bodger
SKF and FAG are good makes
zaust
- Zone day release
Dealer price is £147 + VAT for a front wheel bearing, the dust cap is about £3, you get a new nut with all hub/bearing assemblies
zaust
- Zone day release
The SNR ones from ECP definately come with the big nut - I have a pair of new genuine dust-caps if you need them
Andyboy
- Alpina Colada
I've found the cheap ones a bit growly - you can feel the bearings aren't that smooth when you turn them.
I'd go for SKF which is original equipment. If you have to reuse the nut, use some threadlock - in 99.9% of the time, you have a fresh bit of nut to stake over.
Bristol_Jer
Thanks for all the replies
Does it matter whether you fit ABS or non-ABS bearing hubs? Most I've seen for sale have the ABS ring. My car doesn't have ABS but would it matter if I fitted wheel bearings with the ABS ring to my car?
Doesnt matter if they have ABS rings or not then in your case, the front bearings always come with the hub flange, ive never known them not to
