Joining Brake Lines
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Mar 04, 2012 5:55 pm
Refubed the rear end, but didn't replace the entire front to rear brake line; I put in a join near the fuel filter.
Now it's come to bleeding, and I've got fluid pissing out of the join, so I obviously did something wrong.
I used a male nut on one side, a female nut on the other (both M10x1.0) with double flares on both the old steel and new cunifer pipe. Is that correct, or should I have used different unions or different flares?
kam-325i
Post Sun Mar 04, 2012 6:00 pm
Post Sun Mar 04, 2012 6:02 pm
Grrrmachine wrote: I used a male nut on one side, a female nut on the other (both M10x1.0) with double flares on both the old steel and new cunifer pipe. Is that correct, or should I have used different unions or different flares?
This is the way I usually do it, but one of the pipes
needs a double flare.
chh137
Post Sun Mar 04, 2012 6:16 pm
I usually put single flare on steel pipe side and double on new pipe (copper or cunifer)
Works every time
Grrrmachine
Post Sun Mar 04, 2012 7:04 pm
chh137 wrote:I usually put single flare on steel pipe side and double on new pipe (copper or cunifer)
Works every time
Is single flare where you don't use the flaring die, just the nose of the flaring tool?
kam-325i
Post Sun Mar 04, 2012 7:07 pm
Single flare looks like the end of a trumpet....
just use the pointy end of the flaring tool, no die.
chh137
Post Sun Mar 04, 2012 7:11 pm
Single flare is operation 1. Double is operation 1 then operation 2.
In other words....... single flare is convex........double flare is concave. HTH
