As above, friend of mine has a pair of good condition 750i calipers (4 pot Brembos) and was curious if it was possible to retro fit them to an E30 setup with ABS?
Too much hassle, or viable?
750i Brembo calipers onto an E30 - Possible?
Silverfang
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
craigieeb
http://www.e30zone.net/modules.php?name ... c&t=214936
Anything is possible : )
Iv got them fitted to mine
M50 Turbo!!!
I shall say no more
Silverfang
Do they bolt straight up? or require a mounting bracket mod?
Which master cylinder did you use along with discs from which car?
Just read the thread
Does look good but theres info that it doesn't have.
craigieeb
They don't bolt straight up you will need an adaptor ...
http://www.e30zone.net/modules.php?name ... c&t=192838
I have just used the standard master cylinder, but im also using a servo from a clio, because of the M52 2.8 conversion I have
disc wise I'm using these...
http://www.ebay.co.uk/itm/290368723148? ... 2131wt_902
or you can use TT disc's and have them modified, centre bore taken out 1mm, then
re-drilled to 4x100
re-drilled to 4x100
M50 Turbo!!!
I shall say no more
redcar
Craig, do those 312mm vw fit without any modifying?
craigieeb
Yep, straight fit matey, tbh their not bad discs
M50 Turbo!!!
I shall say no more
redcar
Thats awesomecraigieeb wrote:Yep, straight fit matey, tbh their not bad discs
So I suppose all needed is some calipers, custom bracket and those discs which fit straight on.
Is the centre bore on those discs suitable for e30 then ?
craigieeb
Yes
Yes
And
Yes
Those discs have already had the center bore milled out,
So they just slot straight on
Yes
And
Yes
M50 Turbo!!!
I shall say no more
redcar
Hi I just read on the ad that those discs are 65mm
Isn't the e30 hub 66mm?
craigieeb
Ahhh yeah it's all coming flooding back now,
I asked them to open the bore by 1mm
M50 Turbo!!!
I shall say no more
