lightweight windows
Rallyprep_UK
- formerly Driftnething
I am just lookiong for opinions on lightweight windows.
For my track car I would like something which is thermoformed and has a slider in each front door glass.
Has anybody any advice for me ? A recommended supplier would be great. It is not something I have bought before and I dont want to just buy any old thing...
As far as I can tell from searching there are differences in thickness and some are thermoformed which I am guessing that means "shaped" as per stock glass ?.
I would like to keep as much of the stock appearance as possible,although that is not the priority here of course...
Thanks in advance,
Will
Thanks in advance,
Will
rix313
The plastics for performance ones are what I'd go for. They make them to fit in the standard rubbers, and like you, I prefer something 'stock' looking.
Rallyprep_UK
Thanks bud,
I am looking to use something like this and gut the front doors. The window will be fixed into position and a slider placed in each door should help me stay cool...
They do state one of the "REAR 1/4 WINDOW TYPE" as "Chrome Frame fit 1/4 Window".
I am guessing this is what I want to just swap with my oem glas into the existing seal and trim ?
Will
Will
Rallyprep_UK
And the price is not bad for the kit @ £306+vat inc 2 x door sliders...
£550.00+vat for the windscreen is out of my budget though
DasChin
How much for a full set from P4P? Ouch!
check out ACW Motorsport for polycarb windows.
www.acwmotorsport.co.uk
I just got a full set of windows, 3/4s, rear window and sliders for £200. Plus postage.
Works with oem rubbers too.
Unless it was hardcoated/scratch resistant and heat formed to work with standard winders I wouldnt be interested. You can buy a sheet of makralon for about £60
Rallyprep_UK
Hoobs
Keep a look-out for second-hand windows. I got the fronts new & unused for £30, the rears for £25 and the rear off eBay. I only have a slider in the drivers window, although I may have to remedy that or fit a cold-air intake as I'm sure it'll get quite sweaty come summertime.
Well worth doing on a lightness & lower centre of gravity front though.
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
2002
DasChin
yep all above the above is done with ACW.DanThe wrote:Unless it was hardcoated/scratch resistant and heat formed to work with standard winders I wouldnt be interested. You can buy a sheet of makralon for about £60
with the rear 3/4 windows they are fine. I have the pull out windows but a set of std 316 rubbers on the rear and you are fine.
for HALF the price of P4P I know which way I would be going!!
Demlotcrew
Nick are the ACW heat formed?
Rallyprep_UK
http://www.ebay.co.uk/itm/110802003949? ... 1423.l2649
Has anybody experienced Mike Templar's windows or services ? These ae cheaper again !
Will
Will
miketemplar
Hi, Come try me! I've been in the windscreen trade over 30 years, heavily into my motorsport, and can do moulded (thermoformed) windows too. Advice will only cost you the price of the call, and I won't do you down.
Can you do windows that work with manual winders Mike?
Rallyprep_UK
Excellent !!miketemplar wrote:Hi, Come try me! I've been in the windscreen trade over 30 years, heavily into my motorsport, and can do moulded (thermoformed) windows too. Advice will only cost you the price of the call, and I won't do you down.
