Hi All,
in the last 2 days the biting point of the clutch on my 325i touring has pretty much hit the floor. I'm guessing it may have something to do with the cold snap, perhaps fluids have contracted in the cold?
Anyway, just wondering if there are things I can easily check to try to get it to be more drivable as I need to pick up my parents from the airport this evening.
Cheers for any help.
Hitman
HELP - clutch biting point on the floor
Ant
- Retired Team Member
check there is fluid in the clutch res, if its empty/low the pedal will bite on the floor
top it up and allow gravity to force any air to the top, then try the clutch again.
assuming operation is improved, bleed the slave cylinder, top her off again and monitor the level over a few days.
If its dropping check the footwell in the drivers side for fluid loss, and check the slave cylider is dry, you'll need to remove it from the gearbox to check the end where the pushrod sits.
HTH
HTH
Email FTW
hitman
Is there a particular type of fluid to use to top it up if it is low?
Gwynleym10
brake fluid! Dot 4 and above.
Master cyclinder may also be leeking, thats based behind the pedal, so if its wet around there....
hitman
oh well, Clutch won't work at all now!
Tried topping up the fluid and it only took a bit but still won't work.
Poop!
Poop!
johnono
is there any resistance in the pedal at all?
max_crox
It might me the slave cylinder has gone or even the master cylinder. The bite point would sink to the floor if I kept my foot on the clutch for a while.
Slave Cyliner is about 30ish quid and an hours labour and master is about 35/40 with an hours labour.
RICHIE74
Had this on my Sport . Try bleeding first but i reckon it will be your slave cylinder . Easy to do once the car is off the ground . Mounted on the gearbox , passenger side .
hitman
Thanks for the tips. A mate is gonna be helping me taking a look this weekend... gotta drive the Missus's Clio until then... and that has started throwing a ratty too!
hitman
clutch hydraulics sorted! Changed master and slave cylinders, I think the slave was leaking but changed both anyway. All is back to normal now, even passed MOT...after a new back box!!
