please help with relays?
floyd69
please help me with my relays,ive had a running problem since ive owned the car.but since scouring the internet people are saying to check my fuel pump relay.but my car doesnt have one in the middle!is this my proble?it might help if i say what model she is,e30 325i sport.many thanks to all that view or reply to my thread.cheers
Grrrmachine
- E30 Zone Wiki / Team Member
From the Wiki:
"The fuel pump relay is another relay in the engine compartment, covered by a black plastic hood. It is identified by the green/purple wire going to its base.
First, remove the fuel pump relay from its socket, and link together pins 30 and 87 with a short length of wire. You should easily hear the fuel pump whirring away under the rear seat of your E30. "
But what problems are you having with your sport that makes you think the relay is suspect?
floyd69
yeah i know where they are mate,but i only have two under the black cover the middle one is missing.ive just got a rought but hard to start engine,and it starts to jump around after a wile.but other times its ok.so im doing a bit at a time to restore her to former glory.ive done since ive had it.
plug leads
plugs
dizzy cap
rotor
air filter
fuel pressure reg
and fuel filter,its got better but not perfect.
thanks for your help grrrrr
plug leads
plugs
dizzy cap
rotor
air filter
fuel pressure reg
Grrrmachine
Grrrmachine wrote:It is identified by the green/purple wire going to its base.
Doesn't matter what position your relays are in, since the sockets are moveable. Look at the wires to determine which is the FPR.
Is it rough starting only from cold, or from hot too? If you're going to throw money at the car, get the injectors renewed via Injectortune (on here), and check all your rubber hoses for air leaks.
floyd69
good man il check it in the morning,funny enough that was going to be next on the list.yeah its does seem to be worse from cold.cheers
