E30 design faults...
BEERBOY123
Let's be honest, it's such a well designed machine all round, but there were a few petty mistakes I reckon, such as:
On two doors: the seat belt always snags the seat lever when you are buckling up;
The steering is too low geared (yes I know we know);
The driver's seat doesn't slide back enough for anyone over 6 feet.
Any others?
Any others?
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
kam-325i
Boot entry to high, rear lights should of been part of the boot lid.....
rix313
Ranchero
Dumb cardboard panel under the steering wheel.
- Homo Hair
They attract the wrong kind..
Dezzy
- CR24v it's a lifestyle
THIS!Jhonno wrote:They attract the wrong kind..
such as what ?BEERBOY123 wrote:Let's be honest, it's such a well designed machine all round, but there were a few petty mistakes I reckon, such as...
Buy another turd Designed in the late 80's from another manufacturer and I'm sure you will find a lot more wrongness than you will on an E30 !
Topblag
I've just had a vauxhall Insignia for 5 days. Very little visibility due to huge pillars and small windows and electric steering which has no feedback at all when doing more than 10mph.
Point being, they're still making cars full of major design flaws.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
leeparkes
Vunerable sumps.
I had one, the handbrake is stupidTopblag wrote:I've just had a vauxhall Insignia
BMWE30325
rust lol
Topblag
Makes handbrake turns impossible, fecking thing won't go on at 35mphe30topless wrote:I had one, the handbrake is stupidTopblag wrote:I've just had a vauxhall Insignia
harry_p
A lash up of a rhd conversion
Lack of galvanising
Appalling headlight level adjustment system
Non-folding rear seats
Lack of rear legroom but a massive boot
Aux fuel tank on the m3 is virtually impossible to fill completely
Bbs centre caps too complicated / expensive / easy to steal.
Two valves per cylinder short on all but a pair of crappy 4pots
Lack of galvanising
cheers,
harry
harry
madmax1410
none adjustable steering wheel! and if you didnt have an electric arial and a tech 2 spoiler it catches the ariel and breakes it if the boot close's!
jaymos
Im 6ft 3 and never had a problem tbf.BEERBOY123 wrote:Let's be honest, it's such a well designed machine all round, but there were a few petty mistakes I reckon, such as:
Any others?
only problems for me were no rear parking sensors, inbuilt sat nav, massage seats, infa red display and maybe a head up display and g meter.
SI board batteries fail and tricky to replace.
Glovebox torch tends to somehow end up behind the centre console, or its rather crudely charged battery goes manky.
Dashboard cracks.
Door locks seize up in very cold weather.
Headlamp wash/wipe system tends to fail, valves to windscreen washers also clog up.
Kangarooing/driveline shunt.
Tail-happy in the wet.
Dashboard cracks.
Rust rust rust and oh er RUST!
jmccall85
miss my mk4 golf onesrix313 wrote:No cup holder.
appletree
Crappy bonded sun roof cassette with poor rust proofing
Not so much poor design but rear arch liners would have been a good idea
A jack that doesn't dint your door when you lower the car down again
Same here - on my 5th E30 and the driving position/headroom has never been an issue.jaymos wrote:Im 6ft 3 and never had a problem tbf.BEERBOY123 wrote:Let's be honest, it's such a well designed machine all round, but there were a few petty mistakes I reckon, such as:
Any others?
brettE30cab
Weak soft top motors!
And the fold in the plastic window when roof is down.
I also think the bonnet should open the other way.
Jim320i
- E30 Zone News / COTM Team
The bonnet openning the other way round wouldnt look right though!brettE30cab wrote:Weak soft top motors!
It can be a git to work on though if your arching yourself over and into it... Best thing is to just remove the bonnet all together, but then its a git lining it back up, which is why mine is fitted back on side ways
sweep
These were not a patch on such as your maestro's,montego's in there day
Billwill
Only design fault was that they stopped making them
redcar
Pedals are too far to the right, relative to the steering wheel.
e301988325i
Central locking wiring that unnecessarily loops through a door connector which is prone to corrosion.
C101 socket is a problem area that needn't have been.
Heated seat switches in the wrong place.
Blue temp sensor, why do they fail so often when the brown one never does!!!???
I said:
e30topless said:
lock the wife in there
- **BANNED**
Mostly,saloon's/cabbie's are pretty good,very little that should not have made it into production,but tourings....
1 The rail the rear seat cushions hinge on blocks the fuel pump hatch.
2 Poor access to rear top mounts
3 Uneven load floor
4 Still a cill to lift over
3 Uneven load floor
Youth is wasted on the young.
Jim320i
I love do love the fact that BEERBOYS usual attempt to cause friction on the zone hasnt worked
Touring_IOM
Only experience with touring's so:
1: The height between the floor and the roof is too small. trying to fit something relativity tall is nigh on impossible
2: Rusty tailgate slapped on a well rust protected car.
3: Back doors are tiny making people look awkward getting out. getting children out is worse.
4: I just bloody hate the way you have to get to the rear lights to change a bulb, that cardboard thing is a bugger to get back in
5: poor glue what stuck the headlining up (for £17,000 in 1990 you'd expect some decent glue)
6: Crash protection pretty naff but what can you expect for the 80's.
Apart from that it is a mean lean grill... er driving machine.
LondonTom
My thoughts exactly!Jhonno wrote:They attract the wrong kind..
Ajsingh
This!!!!Ranchero wrote:Dumb cardboard panel under the steering wheel.
Oh and im 6foot 3inch abd have no issues driving any e30. Although only some about 5 foot can sit behind me (lol tried this last night)
E30 Crazy!
jimf
The rear hood windows on the cab should have been a lot easier to replace, mine is sewn in but i think some later ones were zipped.
BEERBOY123
Not this time, just interested in little foibles to be aware of. Wonder what was wrong with the RHD conversion as mentioned on here? Seems a good job to me?Jim320i wrote:I love do love the fact that BEERBOYS usual attempt to cause friction on the zone hasnt worked
leeparkes
They should of been 5 stud like the rest of the range.
harry_p
Offset pedals and the stupid crank arm mechanism for the brakes, and a separate resevoir for the clutch fluid, handbrake on te wrong side of the centre console.BEERBOY123 wrote:Not this time, just interested in little foibles to be aware of. Wonder what was wrong with the RHD conversion as mentioned on here? Seems a good job to me?Jim320i wrote:I love do love the fact that BEERBOYS usual attempt to cause friction on the zone hasnt worked
A rhd one isn't horrible or anything, but try a lhd car and everything feels much more natural, including having a footrest on the wheel well which means the pedals don't all have to be shoved over.
cheers,
harry
harry
