carbs or throttleboddies??
WEEMANDANBRITTON
i want to puteither some bike or throttle boddies on my m20!! can any make any sugestion on what to use or the best way to go aboutit???
- **BANNED**
WEEMANDANBRITTON wrote:i want to put either some bike or throttle bodies on my m20!! can any make any sugestion on what to use or the best way to go about it???
dave525
article in a magazine this month about six bike carbs on an m20.think its practical performance car
nickphine
Carbs all day every day, most people nowadays have never driven a car with (properly) set up side draughts on and so don't know how great they are. In terms of outright power, tb's win hands down, in terms of working well with the human brain and right foot analogue carbs are a joy to use. If you like to plant your foot out of a corner and let a computer drive then it's tb's, if you like to feed the throttle in and let your brain be in charge of 'traction control' then it has to be carbs...
fowler
- Boost Junkie
LOad of old shite TBH too much effort for bugger all gain IMHO
EX A-Tech Workshop bitch !!!
gone but not forgotten
fowler wrote:LOad of old shite TBH too much effort for bugger all gain IMHO
This AND expensive to fit and set up PROPERLY .
harry_p
i have no idea what youre talking about. you seem to be confusing throttlebodies with traction controlnickphine wrote:Carbs all day every day, most people nowadays have never driven a car with (properly) set up side draughts on and so don't know how great they are. In terms of outright power, tb's win hands down, in terms of working well with the human brain and right foot analogue carbs are a joy to use. If you like to plant your foot out of a corner and let a computer drive then it's tb's, if you like to feed the throttle in and let your brain be in charge of 'traction control' then it has to be carbs...
a car on itbs will bite just as hard as a car on carbs if you plant your foot at the wrong time.
even more so in fact because they react far quicker than a carb can, and tend to give more mid range grunt.
even if you stick an m20 on carbs you're still going to have a computer controling the ignition, so why not let it do the fuelling too?
there's a reason why carb s are old tech, properly mapped throttlebodies are more responsive, give smoother more progressive power with more flexibility, better economy and smoother idling with aggressive cams.
i'll admit that like for like, and properly setup they can both give the same peak power though, and i suppose that's all that matters to some people.
cheers,
harry
harry
mrLEE30
carbs need constant adjustment to compensate for air temp/density they also require cleaning regular to get the best from them - ask anyone who races carts how much difference a well sorted and cleaned carbs makes, and how quickly they can "go off" over a day as the temp changes.
TB use the computer to do most of the tuning on the fly, thus for an everyday usable car they will always be better to drive with.
e21Jason
Had carbs and throttle bodies on an m20 carbs should only be used where required by race regulations. EFI wins on transient throttle and engine tractability over carbs
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
e301988325i
You'll need to hire some pirates to get you an oil tanker if you want to run an M20 on carbs, single figure MPG here we come!
I said:
e30topless said:
lock the wife in there
duracel79
Two power/torque curves for an M20 on Dbilas TB's and Emerald ECU.
2.7 and 2.5. Both with very smooth flat torque curves ideal for road driving.
stew72
the point above about fuel consumption is correct to a point, but thats only applicable to DCOEs and the like that are set up for outright power gains in conjunction with other engine mods. For example a standard 100ish bhp in an escort rs2000 would probably manage 30 mpg, the same engine tuned to 160bhp on twin 40's fitted to my westfield would struggle to give much better than 15. On the flip side I had a couple of 2 litres 924's last year on standard and one on twin 40's, I can't be certain about power (the car on the 40's did seem a little quicker) but the fuel consumption on the carbed car seemed only marginally worse.
As for tuning, I owd my westfield for a little over a year and only ever needed to tune the carbs once, the porsche as only ever tweeked at MOT time.
Buying and fitting webers correctly can get expensive and if I was on a budget I'd certainly consider bike carbs on a tuned engine. I know a couple of people who have fitted bike throttle bodies in conjunction with megasquirt sucessfully, but thats also fairly expensive to do properly.
