club sport rack
hongkongfuey
Mad-tango-geezer
Post Wed Feb 29, 2012 1:13 pm
Any one give me a quick heads up on this, track rod ends which ones? Spacers top or bottom? Is there a how too or wiki?[/i]
with cars like mine,
maxfield
Post Wed Feb 29, 2012 1:22 pm
I've put spacers at the bottom. I've used E36 track rods and ends. (Only because I bought them for an E36 I had an never fitted them).
Yes there is a Wiki.
suchy
True Zone Relic
Post Wed Feb 29, 2012 1:36 pm
I found this thread quite useful also dude;
http://www.e30zone.net/modules.php?name ... c&t=212923
Post Wed Feb 29, 2012 9:15 pm
You can also use E30 track rods/ends I believe?
sweep
Post Wed Feb 29, 2012 9:24 pm
e30 tie rods and t/r ends
rix313
Post Wed Feb 29, 2012 9:25 pm
Spacers on top. E30 inner and outer track rods.
redcar
ImysE30 wrote:You can also use E30 track rods/ends I believe?
that is what I'm using, along with cut e46 boots.
With the e46 inner and e36 outer, the stock e46 boots can be used and I think that this is the best solution.
redcar
Post Wed Feb 29, 2012 9:26 pm
rix313 wrote:Spacers on top. E30 inner and outer track rods.
Ideally the rack would be on the rear holes with spacer below the rack. Only if clearances allowed :cry:
Post Wed Feb 29, 2012 9:30 pm
Is there any difference in using the E36 stuff?
spook
League two here we come !!!
Post Wed Feb 29, 2012 9:32 pm
Ive got some spacers here :cool:
hongkongfuey
Mad-tango-geezer
Post Wed Feb 29, 2012 11:01 pm
Thanks for all replys sorted
Post Wed Feb 29, 2012 11:26 pm
Have you gone with E30 track rods or E36 track rods then?
