Flywheel ID and which clutch?
Alburglar
Post Wed Feb 29, 2012 12:59 am
Can anyone confirm that this is a single mass flywheel?
I had always assumed that it was because it came off my m40! And the only reason I question it is that the flywheel attached to my new M42 engine is identical.
Assuming it is single mass, I should buy a clutch kit for an M40, right?
But what clutch do you buy for an m42 with a OE single mass flywheel. M40?
M42 - rightness! with proper 4.27 LSD
Jos
Post Wed Feb 29, 2012 10:55 am
Dammit I didn't take a pic of my M42 with dualmass on it..
What did the engine come from? My understanding was that only the e36 M42 with aircon/climate had the dualmass. If it's an e36 engine make sure to check the spigot bearing size! :)
Clutch should be the same for both M40 and M42, I used the M40 one on my M42 after swapping the flywheel over.
'94 e36 tree climber
Alburglar
Post Wed Feb 29, 2012 11:12 am
Ok that's good. I can get my clutch bought now.
It's e30 m42
rix313
Post Wed Feb 29, 2012 12:05 pm
Looks like a single to me. Taking the clutch off will soon tell you.
Alburglar
Post Thu Mar 01, 2012 1:28 am
Yeah it is a single. Got the clutch off today and fitted a new m40 one. Ta
razler
Post Mon Apr 30, 2012 1:19 pm
Hmm that's the same as my m42 flywheel, I always thought it was a duel mass as it looks twice the weight of a normal flywheel!
What makes a duel mass flywheel a duel mass??
Jos
Post Mon Apr 30, 2012 2:30 pm
dualmass has a sprung centreweight:
http://c4owners.org/plugins/faq/faq.php?0.cat.10.139
