Fastener kits for an E30 resto
Topblag
Post Sun Feb 26, 2012 4:33 pm
I've got a resto which will be getting started soon and thought it would be prudent to purchase a job lot of standard nuts and bolts, and not at main dealer prices.
I've had a quick look online and can't see anything obvious - anybody have any recommendations or info on commonly used sizes which I'll need ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Kedge
Post Sun Feb 26, 2012 5:48 pm
While i've been doing my car i've found you can only really do it section by section, there doesn't seem to be that much that is really commonly used enough to warrant stocking up on.
Yuo might be about to get a few things from a local hardware store though.
Instagram - Kedge85
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Feb 26, 2012 5:53 pm
Irritatingly, there seem to be very few "standard" parts on a BMW. Everything can be undone with a few standard spanners, but every bolt is specific-for-use, plus plenty of BMW clips and rubber nuts (like the ones holding on the wheel arch liners and fuel hose cover).
I'd say your best bet is to go through RealOEM, look at all the nuts and bolts listed for everything you plan to remove, and then just buy them in advance rather than a bulk box of 100 "standard" bolts.
Jozi
Post Sun Feb 26, 2012 5:56 pm
I got a lot of the nuts and bolts for the subframes and the like from a nut and bolt place. I printed of all the realoem diagrams and listed the nut/bolt sizes where mentioned. Measured all nuts and bolts to get the thread pitch. Drop me a pm and I can email it if you want?
Post Sun Feb 26, 2012 5:59 pm
most of the nuts and bolts on these turds are Passivated when new, a place near me re-passivates them after a light shot blast, and it cost peanuts for a big bag full doing :D
Depending on how Homo you are.. there's nothing as nice as shiny Dealer nuts and bolts :o:
they aren't all that expensive I have got lots of them from here, http://www.bmminiparts.com/
Kedge
Post Sun Feb 26, 2012 6:02 pm
Some of them are becoming NLA now though.
Rear shock bottom bolts
steering rack mount, nut and bolt.
Instagram - Kedge85
Jozi
Post Sun Feb 26, 2012 6:03 pm
e30topless wrote:most of the nuts and bolts on these turds are Passivated when new, a place near me re-passivates them after a light shot blast, and it cost peanuts for a big bag full doing :D
There's quite a big price difference between BMW (or bmminiparts) than there is getting the same size nuts/bolts from a nut and bolt shop.
I was sure I price up a lot of them but I can't find where I saved the pricing.
Grrrmachine
Post Sun Feb 26, 2012 6:04 pm
Jozi wrote:I got a lot of the nuts and bolts for the subframes and the like from a nut and bolt place. I printed of all the realoem diagrams and listed the nut/bolt sizes where mentioned. Measured all nuts and bolts to get the thread pitch. Drop me a pm and I can email it if you want?
Can you PM it to me, Jozi? That sounds Wiki-worthy
Jozi
Post Sun Feb 26, 2012 6:27 pm
Sent you a pm there :thumb:
Post Sun Feb 26, 2012 6:44 pm
most of the bolts/nuts on the subframe and associated bits are High tensile, usuing Japanese monkey metal shite isn't really a good idea 8O
using Stainless fasteners is no better, Daimlerman proved this when his calipers fell off !!
you would be suprised how little you are saving too,
one thing I like about working with 20+ year old BMW's is the way they always come apart easily, can't remember the last bolt I sheard off ?
Jozi
Post Sun Feb 26, 2012 6:59 pm
I sheared a front subframe bolt taking it of (scrap shell anyway) but other than that (and the plates on the rear sill) nothing sheared and did come.
I must check but nearly sure any bolts I got were the same strength grade as the original part. I found a print of for all the bits I priced, came to 350euro but there's other stuff there as well, can't find it saved in a spreadsheet or I'd total it up to see what it was.
Topblag
Post Sun Feb 26, 2012 10:39 pm
Thanks all. I think Topless is winning so far. I've got bags of E30 bolts that could come back to life.
I also like the idea of going through the build diagrams to work it out.
**BANNED**
Post Mon Feb 27, 2012 12:11 pm
R/H bit under the mangled brake pipe is the remains of THE BMW SUPPLIED PASSIVATED BOLT,not a stainless replacement,I strongly suspect that the BMW bolt has a fine pitch thread....
Here we see the remains of the bolt before it was drilled out.
Please get your facts right,Steve!
Grrrmachine
Post Tue Feb 28, 2012 6:08 pm
Topblag
Post Tue Feb 28, 2012 6:11 pm
nice work gents. :cool:
Jozi
Post Tue Feb 28, 2012 6:26 pm
That didn't take long, glad it was of some use to you! I will add though to check your own nut's/bolts to be sure, I know my front wishbone was different to what is listed because I replaced them both.
Jim320i
E30 Zone News / COTM Team
Post Tue Feb 28, 2012 6:31 pm
Grrrmachine wrote:All credit to Jozi for this one:
http://www.e30zone.net/e30zonewiki/inde ... _and_Bolts
Hats off to you and Jozi on this one :cool:
Does mean you need to do this with every other part now too! :mad:
Jozi
Post Tue Feb 28, 2012 6:42 pm
Jim320i wrote: Does mean you need to do this with every other part now too! :mad:
Hehe :D
Dezzy
CR24v it's a lifestyle
Post Tue Feb 28, 2012 7:21 pm
I just use anything off the garage floor. Copper-Slip and windy gun gets it on. Checking thread pitch is for Hom's! winkeye
**BANNED**
Post Tue Feb 28, 2012 8:17 pm
Dezzy wrote: Checking thread pitch is for Hom's! winkeye
Hope that I am not the poor sap who follows you..... :mad:
Post Tue Feb 28, 2012 8:37 pm
A good list, but with one reservation. Most bolts are of ordinary 8.8 grade, but a few are the stronger 10.9 grade, and the wiki article doesn't specify which.
Post Tue Feb 28, 2012 8:50 pm
daimlerman wrote: Here we see the remains of the bolt before it was drilled out.
My Apologies Malc, but how strange is that ?
is the newer metal used on bolts inferior or did you tighten it too much or not enough ?
**BANNED**
Post Tue Feb 28, 2012 8:54 pm
My Apologies Malc,
Thank you.
Post Tue Feb 28, 2012 8:59 pm
e30topless wrote:did you tighten it too much or not enough ?
**BANNED**
Post Tue Feb 28, 2012 9:14 pm
Oh you of short,or confused,memories!
This is going well off the OP's original post and going over ground trodden some years back.
I had just got the cabbie MoT'ed and was still 'shaking down' a few niggles,coming home from work at 7am,I approached a roundabout that was about a 100 yards from home,touched the footbrake to be met with a clunk,loss of steering and brakes.I stopped the thing without further drama and found a completely deflated front o/s tyre.Removing the wheel revealed;
The lower caliper bracket bolt had dropped out,allowing the caliper to swing upwards into the well of the wheel,punching a hole about an inch square.This was most likely due to me failing to torque the caliper bracket bolts up to the recommended 80ft/lb,NOT TO ME USING STAINLESS STEEL BOLTS! :D
Jos
Post Tue Feb 28, 2012 9:36 pm
you can't use stainless bolts, they just aren't strong enough for most car applications. 1 place you can replace fixings with stainless is where they are going into aluminium, timing covers, water pump housing and exhaust manifold studs spring to mind as they don't cause corrosion.
'94 e36 tree climber
Dezzy
Post Tue Feb 28, 2012 9:47 pm
Not again surely :eek:
bodger
Post Tue Feb 28, 2012 10:02 pm
the only stainless steel parts on a bmw should be the exhaust :D
Grrrmachine
Post Tue Feb 28, 2012 10:03 pm
Some of the items do specify that they're 8.8, but you've made a fair point. I'll add the info as it comes my way.
Post Tue Feb 28, 2012 10:47 pm
bodger wrote:the only stainless steel parts on a bmw should be the exhaust :D
Its all about mild steel BMW exhaust!
