Air intake hoses... previous work bodge or not.. and part No
G-Bear
Post Tue Feb 28, 2012 12:25 pm
Was checking through the vacuum hoses that are connected to the IVC and air intake etc today, found a few that needed replacing. After looking up the part numbers, the diagrams didn't seem to match up with how the hoses were assembled on my 318is...
Below are the hoses that need replacing..
Below is where they where housed..
Hose A connects up under into the throttle housing and to the hose running to ICV.
Hose B runs up to the rubber boot (which connects the Air intake to the throttle housing). Both hoses have been out before as they're bound in insulation tape to seal up the holes in them. Is there a chance these have gone back the wrong way?
I sure I'm a silly arse but on the parts diagrams they appear to be set up the other way(diagrams below). I'm struggling to tell as they don't appear the same shape and size on the diagrams as they are in the flesh, but don't know how detailed the diagrams are. Its always been set up that way and I've had the car for over 3 years and have driven it like this all the time.
Just a bit flummoxed and hoped you's lot could slap some sense into me..
[/img]http://img576.imageshack.us/img576/3641 ... 12.png[img]
If this is set up correct could someone just let me know I have the part numbers right..
Hose A 13 54 1 739 248
Hose B 13 41 1 721 909
Many thanks..
Greg
G-Bear
Post Tue Feb 28, 2012 12:29 pm
Sorry the other diagram didn't seem to load the first time...
G-Bear
Post Tue Feb 28, 2012 5:10 pm
Hose B might be longer brand new than displayed in the above pic, as one end has been cut/perished/bitten off..
mwggriffiths
Post Tue Feb 28, 2012 7:24 pm
The part numbers are correct, however your hoses are connected up the wrong way around currently.
Currently you have:
part 25 (top diagram) ---> part 14 (top diagram)
part 17 (top) ---> part 16 (bottom).
This should be as:
25 -> 16
17 -> 14
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
G-Bear
Post Tue Feb 28, 2012 9:02 pm
I thought as much, cheers. Was driving me bonkers earlier whilst looking at those diagrams.
Like I said earlier; its been like that since I've owned the car (over three years). Do you know how this may have effect the engine??
TheDutch
Post Tue Feb 28, 2012 9:07 pm
Whilst tracking down a vacuum leak I replaced all the original hoses (which were actually fine) with a few bits of generic stuff as per:
http://www.m42club.com/forums/showthread.php?t=2742
johnl320
Post Tue Feb 28, 2012 9:10 pm
I've also been sorting out the M42 mess
http://www.e30zone.net/modules.php?name ... 3&start=25
G-Bear
Post Tue Feb 28, 2012 9:58 pm
Thanks TheDutch... This is just what I have been looking for to read through..
And thanks John320.. I was flossing through your thread earlier today..
I noticed signs of coolant leaks under the inlet manifold today so might do the whole lot. Looking forward to it too.. satisfying pulling off, replacing and cleaning..
