Best way of making a door handle with the interior gutted
kipsy
Post Fri Feb 24, 2012 12:14 pm
Hola. I'm going on a bit of a lightening mission on my e30 325 to loose a bit of excess fat. I'm thinking about getting some pollycarb windows and totally gutting the doors. How can I open the door from the inside? I'd rather have some sort of handle or neat idea rather than a big hole with a bit of wire. I can get hold of some plastic corragated card which I might put over the hole which ways next to nothing. Any ideas or what have you guys done?
milescook
Post Fri Feb 24, 2012 8:09 pm
Might sound daft but I've seen pics of this - I plan to do it myself!
If you're lightening the car, I take it you're taking out the coar hanger handles / grab handles above the doors? Thinking of throwing them in the bin?
Voila! Door handles 8)
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
kipsy
Post Fri Feb 24, 2012 8:48 pm
They were binned before I owned the car. I've got some nylon strap as a door handle now
bimmaman
Post Fri Feb 24, 2012 9:23 pm
As far as I know, the handle is separate to the door card - so if you remove the door card, the handle stays fitted to the door...
bimmaman
Post Fri Feb 24, 2012 9:25 pm
Here's a pic... not mine I might add...
Post Fri Feb 24, 2012 9:35 pm
I really dont see the point, why fck up a decent door that will end up flopping about and looking stupid for the sake of 500g of steel? :?
If you want light doors then get GRP and do it properly.
IMO unless your shaving several KG at a time its not worth it
kipsy
Post Fri Feb 24, 2012 10:01 pm
Not allowed fibre glass I don't think plus too much money. If I totally gut the door and fit a polycarb window it's prob going to save at a guess 20% of the door weight?
kipsy
Post Fri Feb 24, 2012 10:02 pm
I've already removed all electrics and it's got little lightweight mirrors.
Post Fri Feb 24, 2012 10:11 pm
The glass is the big saving, by chopping the door up you wont remove even 1KG
kipsy
Post Fri Feb 24, 2012 11:40 pm
Well I took 85% of the internals out of my bonnet (leaving the bare minimum to close it) and once I weighed everything removed it was 1.5 kg less. When I fitted the bonnet it was really flimsy and broke when i closed it. Fitted a replacement today and went to the gym :)
Mymbrother (kevo) has gutted his bonnet and has it opening the other way on e36 gas struts. Works well
Post Fri Feb 24, 2012 11:44 pm
Why not drill lots of holes in the larger internal steel areas to shed some weight? winkeye
kipsy
Post Sat Feb 25, 2012 11:20 am
Possibility. Will look into it! Cheers for all the help peeps
milescook
Post Sat Feb 25, 2012 1:38 pm
Heat shieling is another 5-10kg, that's just an estimate. All added together feels pretty heavy!
http://racing.cookieonline.net/e30-320- ... elding-e30
Not sure how hardcore you're going though...
Post Sat Feb 25, 2012 1:52 pm
The exhaust heat shields are less than 1kg and do a great job of stopping the transmission tunnel/prop bearing and most importantly the fuel tank heating up, hot fuel = less power.
milescook
Post Sat Feb 25, 2012 2:14 pm
Do you mean on the inside Dan, like in my pics, or outside?
Post Sat Feb 25, 2012 6:24 pm
You said heat shields, so I assumed you meant the exhaust heat shields which are the only ones that come to mind. If your on about the stuff under the carpet its called sound deadening :D
milescook
Post Sat Feb 25, 2012 8:51 pm
Haha! Every day's a school day :o:
Yes - get rid of that stuff 8)
Post Sat Feb 25, 2012 9:42 pm
Mines down to 1000kg now and ive not chopped anything except the front valance as ive fitted a deep tech2 bumper
kipsy
Post Sat Feb 25, 2012 10:36 pm
That light? Not with a 6 pot surely if do good effort!
Post Sat Feb 25, 2012 11:55 pm
Don't forget, an m52 is all-alloy, whereas the M20 is a steel block.
kipsy
Post Sun Feb 26, 2012 9:05 am
I got an m52 in stock :)
mrLEE30
Post Sun Feb 26, 2012 10:35 am
how much do you weigh?
easier for you to loose 5kg then take it out of the car.
then save on fuel weight by adding only the fuel required.
fit a smaller battery, and start it from jump leads, battery only then used for running
kipsy
Post Sun Feb 26, 2012 4:32 pm
I'm about 95kg. Lost a stone since jan. Going down gym to shape up! I'm even starving the navigator haha. He only weighs about 10.5 stone so ideal
