4 Stud to 5 Stud conversion
Emm3
Post Fri Feb 24, 2012 2:10 pm
Do m3's use 51mm struts and arnt the brakes the same size as 325i
Post Fri Feb 24, 2012 2:12 pm
Yes, but NOT 4 stud ones.. No.
harry_p
Post Fri Feb 24, 2012 2:25 pm
Emm3 wrote:Do m3's use 51mm struts and arnt the brakes the same size as 325i
brakes are bigger on the m3, they use 15in wheel minimum, where normal e30 brakes fit under 14s.
cheers,
harry
Post Fri Feb 24, 2012 3:43 pm
If any body wishes to go 5 stud PROPERLY, I have a pair of complete E30 M3 rear trailing arms with brakes etc and a slightly bent o/s front strut (ideal for coil overs0 I also have M3 front brakes and the M3 specific lower strut mounts .
senna
Post Fri Feb 24, 2012 3:59 pm
This is what you need to do it properly!
Post Fri Feb 24, 2012 4:10 pm
senna wrote:Image
+ my rears, job jobbed ! :)
anothere21323i
Post Fri Feb 24, 2012 8:44 pm
You have PM Peter!
jaistanley
Post Wed Mar 07, 2012 8:47 am
I have gone 5 stud PROPERLY in two different ways.
First I PROPERLY fit E30 M3 parts all round. Later I PROPERLY fit a mixture of E36/7 parts.
Both gave excellent handling. You may be surprised to know that using a mixture of E36 parts has yielded much better brakes, better turn in and higher absolute grip.
Jai
