318i Running like Shit when cold
Post Wed Feb 22, 2012 10:08 pm
my 1994 318i m40 Touring has developed a fault, was working fine yesterday until this morning when i went to start it, it took stupid amounts of cranking to start had to give it loads of throttle in the end when it eventually splutterd into life.
When pulling away it kept stalling and coughing till it was above 1500rpm, above these revs it was fine. it started running fine after about 10-15 mins driving when engine was fully upto optimum temp and have been stop starting the all day today doing a few short trips and done around 50 miles and its been fine since.
i'am guessing tomorrow morning when i go to start it to go to work its going to be hard to get going again.
Blue temp sensor ??
Ive not yet inspected dissy and rotor, could engine temp affect these???
Any help would be appreciated :D
zaust
Zone day release
Post Thu Feb 23, 2012 8:02 am
Have a look for air leaks round the inlet manifold. Could be closing the gap as she gets warmer. Fingers crossed for you bud.
M30 Tech 1 Touring on gas.
Post Thu Feb 23, 2012 8:34 am
Air leak, blue temp sensor - even clogged fuel filter/strainer ?
Can't see dizzy cap/rotor arm causing this sort of fault that gets better as it warms up
Dont know if all blue temp sensors are the same but I've got a brand new ECP one I can get posted to you if you need one for a few beer tokens
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Feb 23, 2012 8:37 am
Have a read of the Common Problems for the Air and Fuel systems:
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
Almost all the tests you need to do are covered in those sections.
daymo69er
Post Thu Feb 23, 2012 7:18 pm
i get the same prob mate! changed the temp sensor , spark plugs and fuel filter still nothing just going to take inlet off weekend and have a butchers at that, will let you no how i get on!
sweep
Post Thu Feb 23, 2012 8:01 pm
my 316i lux powerhouse had this problem i tried blue temp switch / removed and re-set tps/tried a afm,in the end it was the icv.
Post Thu Feb 23, 2012 11:03 pm
its running fine again now, ummmm :?
Post Fri Feb 24, 2012 6:42 pm
running fine again, really wierd this one :?
Post Fri Feb 24, 2012 7:46 pm
willnz wrote:If you get a wet cold night, or go through a heavy rainstorm, you could get a bit of condensation/water inside the dizzy cap which could cause tracking (= bad running) while it is there, but stop when the engine warms up and it dries out. Not common but possible.
