bmw leather dye-does it work?
matt86
Post Wed Feb 22, 2012 11:03 am
Hi I've seen bmw leather dyes on ebay and places and people on the forum showing before and after pics, seen some really screwed ones that afterwards look as good as new or near enough. Are these ones that have been done professionally or diy? Is it just a case of brushing it on and it really makes that much difference providing there's no holes in seats?
Where's best place to get it after beige colour, only drivers seat needs doing really.
Matt
Rtaylor2208
Post Wed Feb 22, 2012 11:19 am
FurnitureClinic.co.uk supplies the kits and there have been a few zoners have had good results. Have a look through the care and detailing section there are a few threads in there showing you results.
Its fairly straight forward but time consuming.
matt86
Post Wed Feb 22, 2012 11:22 am
Thanks mate appreciate that, will have a look through, thinking of giving it a go.
Matt :D
Gavla
Post Wed Feb 22, 2012 12:28 pm
liquidleather.com
Have a read through, if you follow their instructions your seats come up looking new! They also match your colour exactly to BMW spec.
I did mine, cardinal red, they came up brilliant. The preparation time is long because you need to wait for drying etc, but worth doing properly.
Let me know if you want any other info.
matt86
Post Wed Feb 22, 2012 12:39 pm
What size dye would I need to do just the front seats? And are there instructions with the kit on how to use it? Cheers matt
Gavla
Post Wed Feb 22, 2012 2:20 pm
I did not buy the kit I bought seperate products. The 250ml Scuffmaster from liquidleather.com should do, with some left over for more coats in the future. There are full instructions with the scuffmaster.
The basic steps are;
1. Deep Clean - let dry fully, I used a hairdryer to speed up the process.
2. Gentle Clean - let dry fully
3. Condition - let soak in a minimum of 24 hrs do again if required, this is the most important step in my opinion as it gets the leather soft and gets rid of surface cracks.
4. Scuffmaster - let dry fully
Its a catch 22 though, depending on the condition of your other seats, you may end up with one brand new looking seat and the rest not so great.
If you haven't cleaned your seats properly before you will be amazed at what is under the dirt.
brettE30cab
Post Wed Feb 22, 2012 3:19 pm
If you have cracked leather you will need a filler, I used a kit from eBay ( trim technique)
matt86
Post Wed Feb 22, 2012 3:25 pm
No just scuffs you know where it goes like grey underneath and colouring comes off, what's best for that? Cheers
Gavla
Post Wed Feb 22, 2012 4:35 pm
Mate, do yourself a favour and read through the liquidleather.com website reviews. There are alot of products out there, I did tons of research on this before I bought it because I was doing all my seats, what I really like is they match the colour exactly for you.
matt86
Post Wed Feb 22, 2012 4:48 pm
Ok will take your advice and have a browse through. Cheers mate
adit
Post Wed Feb 22, 2012 8:01 pm
[quote="bss325i"]
matt86
Post Wed Feb 22, 2012 8:12 pm
Thanks adi, nice one, will do some bedtime reading :)
Kos
Post Fri Feb 24, 2012 1:24 am
brettE30cab wrote:If you have cracked leather you will need a filler, I used a kit from eBay ( trim technique)
personally i'd avoid using fillers. i didnt bother with mine.
matt86
Post Fri Feb 24, 2012 10:22 am
Ok cheers for the advice, I will have a look into this and do some research over the weekend.
Matt :)
Gavla
Post Fri Feb 24, 2012 11:42 am
Normally I would agree with Kos about fillers. However the filler supplied by liquidleather.com is a flexible one, so as long as you are not trying to fill in too much it works well. Again you need to follow the instructions properly for it to work properly.
brettE30cab
Post Fri Feb 24, 2012 12:15 pm
I reconditioned my black leather in my old cab without using filler and the result was fairly good, however I reconditioned my lotus leather using flexible filler and the result were a lot better , as long as the cracking isn't to bad then try it without the filler
matt86
Post Fri Feb 24, 2012 1:38 pm
Ok most the seats are very good condition and just need dying, but they have hairline cracks on fronts and a very small hole on drivers top bolster, what would the advice be really to get these back to as new condition? How much would the kit cost me to do this? Sorry haven't had a chance to look at websites yet, but will look tonight.
If you take your time with this is it nearly as good as getting it done professionally?
Matt :D
Splondike
Post Fri Feb 24, 2012 2:44 pm
I took a punt on a Taurus red trim from a breaker on ebay. I used the gliptone scuffmaster kit on it and it came up a treat...
Before
After
I sent a sample of leather off to Gliptone and asked them to supply a 500ml scuffmaster kit. Once the kit arrived I treated the trim to a good deep clean with a brush and fed it over several days to soften the leather. Then I started applying the scuffmaster initially with a sponge, but found that careful brushing produced an excellent finish, if you have the space/equipment you can spray it too which would probably be the best way.
Mark.
harry_p
Post Fri Feb 24, 2012 2:48 pm
that looks great.
i've often been tempted by these kits, but worried the finish might look fake.
does it look and feel like it should? does it last well? also wondered how it covers over the stitching, whether it looked like it had been painted over :?
cheers,
harry
Splondike
Post Fri Feb 24, 2012 3:02 pm
My leather was particularly hard and still could do with some saddle soap to soften it up. Although I have not tried this yet. I don't think the scuffmaster kit would change the feel too much if the leather was soft in the first place as it goes into the leather rather than painting on to it. As a result of the colouring the stitching will take on the colour yes although it looks alright in my particular colour. But for around £100 I went from a tired trim to a decent looking one.
A chap I know has also successfully re-coloured grey leather seats to Pearl beige using the gliptone flexicote system (and painstakingly stripping down and re-assembling the seats).
Mark.
Gavla
Post Fri Feb 24, 2012 5:01 pm
Great pictures, I wish I had taken before and after of mine! Splondike is spot on, the scuffmaster does not change the feel of the leather, the trick is the preperation as I have already mentioned above. For more stiff leather, as long as you clean it thoroughly and then condition a couple of times before applying the scuffmaster, it should end up being soft.
harry_p
Post Fri Feb 24, 2012 5:06 pm
Great stuff, thanks :D
cheers,
harry
Gavla
Post Sat Mar 10, 2012 6:36 pm
I decided to get my back ones done today so have added pics.
Not quite finished yet but nearly there. Took me about 2 hours to strip whatever was on there before, wash properly and colour.
I will do another coat tomorrow and then condition with leather cream.
http://imageshack.us/photo/my-images/85/rearseats1.jpg/
http://imageshack.us/photo/my-images/21 ... ats2o.jpg/
adit
Post Sat Mar 10, 2012 11:24 pm
[quote="bss325i"]
