fuel pump s50b32
backspring
Post Mon Feb 20, 2012 10:14 am
hi guys ive searched and got more confused.
ive got a s50b32 in my m3, its got a fuel pump in the tank and a external.
i know the b32 uses a 5 bar pump and my stock one isnt up to the task.
i was gonna replace it with a walbro 255 or bosch 040 in tank and remove the external, just leave a filter there.
can i do that or do i need to keep both? should i replace internal pump or external or both
thanks
UweM3
Post Mon Feb 20, 2012 11:02 am
Do you have any issues with the pump? or running issues?
I know some guys with M3's running Alpha-N on S14's running with 5bar but can't remember if they used the M3 pump or another.
Keep in mind, it's not the pump which is rated at 5 bar, it's the pressure regulator.
As long as a pump can supply the AMOUNT of fuel required at a certain pressure, it will be fine.
staley_turbo
Post Mon Feb 20, 2012 11:11 am
Exactly.
But if you do need to upgrade, I have a walbro 255 fitted in tank and it works well and fits fine.
Post Mon Feb 20, 2012 12:19 pm
I would recommend keeping the intank pickup pump and fitting an upgraded external, it would also be a good idea to fit a small swirl pot next to the external pump.
I used a walbro pump in the tank before and had terrible fuel starvation at anything under 1/2 tank of fuel. The original pickup is an important part of the tank/pump design so its best to keep it.
backspring
Post Mon Feb 20, 2012 2:19 pm
thanks guys it doesn't go as well in the top end of the rev range, just trying to eliminate the 20 year old pump. plus i have future mods im thinking ahead for..
so if i were to change just the external, would this effect the performance of the internal? (would it keep up)
what do you recommend for external walbro? bosch? /(best/easiest fit)
is the swirl pot necessary?
jaistanley
Post Tue Mar 06, 2012 3:33 pm
An upgraded external and swirl pot is the best bet. The swirl pot will more or less garauntee you wont have fuel starvation during cornering or on a low tank.
Bear in mind though: I used an M3 (M-Coupé to be precise) pump cut off an E36/7 cage and fitted to an E30 one. I then bought a sock filter very similar to the E30 one with a push on brass connector for the pump from FSE. Never had any issue with fuel starvation at all on my S50B32...
HTH
Jai
RoadHazard
Post Fri Mar 09, 2012 5:46 am
What external pump do you guys recommend for upgrading the stock one?
backspring
Post Mon Mar 12, 2012 1:28 pm
i used a walbro 255 intank, bracket needed to be modified a little. (shorten supply line on bracket, cut mounting bracket for old pump off, secure with steel cable ties.) this was because the walbro pump was taller than the original unit.
i removed external pump, replaced with a 12mm to 8mm reducer and a length of fuel line.(new filter)
runs much better i think my old ones were on their way out
RoadHazard
Post Fri Mar 16, 2012 6:11 am
Out of curiosity I was looking at E36 M3 fuel pumps on Ebay because some people use these in their conversions. Seems like there are several versions, 1 pipe and 2 pipes. I know the E30 intank has 2 pipes so that's probably what we can use. But can the 1 pipe version be used as well? How does it work?
backspring
Post Fri Mar 16, 2012 9:11 am
on the intank pump bracket (e30) one is for a feed to engine and the other is a return. i dont know about the e36 pump/bracket.
RoadHazard
Post Wed Mar 28, 2012 7:14 am
Never mind my ignorance. I took apart the feeder unit last Sat and found out the motor itself had only 1 outlet which connected to one of the pipes. The other pipe was the return pipe. So I recon if I am to retrofit the M3 fuel pump, either one would work, as long as it can build enough pressure.
backspring
Post Thu Mar 29, 2012 11:03 am
update on walbro.
it didnt generate enough pressure on its own so i had to use the stock inline pump aswell.
need to find a better solution for the pump
HenryM3
Post Sun Apr 15, 2012 8:27 pm
In answer to your origional question, Yes, you can run with the E36 EVO pump in the tank on a modified E30 cradle out to the standard filter. Mine has been running like that for 8 years and never a problem.
