1987 1.8i 2 door m10 or m40?
matt_chase
I've just bought my first bmw a 2 door white saloon 318i its abit of a shed at the minute but the intention is to make respectable for next summer! My first project car......
But i have a quick query can anybody tell me if its got a m10 or the m40 engine in? It was first registered 17/11/1987 if thats any help? Hope somebody can help me.... cheers Matt.
kam-325i
It should be fitted with the M40
matt_chase
M40 is that the better engine of the 2? is there anyway of telling by looking at it?
kam-325i
Which is better ? How long is a peice of string........
Telling them apart... M10 has pipes that inject the fuel(similar to early diesel engines) M40 has Injectors on each cylinder. K tronic injection (M10) and L jetronic (M40)
Altought i may be wrong.....
matt_chase
Thanks, gonna have a look tomoz to dark at the mo cant see a damn thing!
rayman
K- jet was only on early M 10 engine {E 21} K jet has seperate fuel pipes from a distributer in the engine bay which go to each injector. L-jet has electric injectors. early E30 316 was carb , 318 was injection. m10 engine has a timing chain m40 has a timing Belt
kirils
it's a pre or post facelift model? cause there are a lot cars from 1987 that are prefacelift, and i think that they are with the m10, but that is a really nice engine too, really strong, my old m10 made god knows how much km on LPG, and i sold it to a guy and he is crashed it (e21) , and the engine was still in OK condition ( it used 1 li oil on 300 miles )
kam-325i
The change for the 318 from M10 to M40 was 04/1987, so you will find a mixture of both from around that time.kirils wrote:it's a pre or post facelift model? cause there are a lot cars from 1987 that are prefacelift, and i think that they are with the m10, but that is a really nice engine too, really strong, my old m10 made god knows how much km on LPG, and i sold it to a guy and he is crashed it (e21) , and the engine was still in OK condition ( it used 1 li oil on 300 miles )
Gwynleym10
Oh dear what a lot of confusion!
1987 should be an m10.
M10 below
M40 below
M10s are Bosch L-jetronic Chain driven rightness,
where M40's are Bosch Monotronic Belt driven wrongness.
I used to have an m10 (had it for 4-5 years) and now have an m40.
The M10 is far revvier, make are much better noise, just generally seams more powerful. Bmw however claimed the opposite, but thats probably more to do with "newer is better type marketing".
M40's suffer from mangled campshafts and noisy hydraulic lifters, expensive and pointless to replace. Noise usually starts at 80 000miles and camshafts really begin to die aroun 120 000. Being montronic they also suffer from dodgy temperature senders crappy Idle control valves etc etc.
M10's have a better highermileage ability, super strong bottom ends. Main problem is that the eat distributer caps for breakfast!
Don't ever think of modifiy an m40, nothing with happen, while m10 can preety easily be modded to 160bhp, but 500bhp is possible (and has been done) with turbos.
enough?
M10 below
M40 below
enough?
Gwynleym10
Oh yea, check the price differences in service stuff at www.eurocarparts.co.uk M10 are a hell of a lot cheaper!
kam-325i
Brabham used a modified M10 back in the old Turbo days (1982 - 87) of F1 to produce a monster 1400Bhp.....Gwynleym10 wrote: while m10 can preety easily be modded to 160bhp, but 500bhp is possible (and has been done) with turbos.
enough?
Gwynleym10
Well yes, but you couldn't do that at home.... The turbo on that thing was as big as the engine!
Fushion_Julz
The M10 is a fine, simple, strong motor.
I used to race a 2002Ti...normally aspirated, on carbs (50DCO Webers) with a Shrick cam, Mahle pistons, fully lightnened and balanced bottom end and a "worked" head that gave 198bhp, reliably, at 7250rpm and would rev happily to 8500rpm...
You can put an engine like that together very easily and not to expensively, too...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
hoshy
- E30 Zone Wiki Guru
After readng this and other stuff I really wish I'd gone for an m10 base.
Anybody know about the s10?
Gwynleym10
Thing is most m10 bases are rusting away! (like my old one...)
s10? I don't know anything about that
S14's Are loosly based on m10s. You can fit a 16v s14 head to a m10 bottom end.
hoshy
if you can find a cheap enough headGwynleym10 wrote:Thing is most m10 bases are rusting away! (like my old one...)
the rust was why i didn't get the 316 carb'd m10... was quite nice though and I fancied playing with carbs but alas the m40 wrongness took over
kam-325i
S10 ? Never heard of such an engine from/for BMW......
320Touring
first time that an m40 ever passed an m10hoshy wrote:if you can find a cheap enough headGwynleym10 wrote:Thing is most m10 bases are rusting away! (like my old one...)
Gwynleym10
eh?first time that an m40 ever passed an m10
M40 could never pass an m10....
Whish I have got the old m10 on a rolling road to see the REAL differences...
kam-325i
Chose M40 over the M10, passed over the M10....Gwynleym10 wrote:eh?first time that an m40 ever passed an m10
320Touring
i was being sarky-m40 passed the m10 cos hoshy chose it-"but alas the m40 wrongness took over"Gwynleym10 wrote:eh?first time that an m40 ever passed an m10
took over------->overtake--------> m40 passing an m10
capische?
Gwynleym10
capische?
Oh i understand! Same here, got m40 now, but its going to binned in place of an m10andahalf(m30!)
My brain had just frazzelled when I found out I had a question about Nuclear power for the Secretary of State for next week
capische?
Gwynleym10
Do you think Matt (first poster) has got enough info on m10s and m40s yet?
kam-325i
How do you stand on this change in policy ?Gwynleym10 wrote:My brain had just frazzelled when I found out I had a question about Nuclear power for the Secretary of State for next week![]()
320Touring
think so-probably actually scared him awayGwynleym10 wrote:Do you think Matt (first poster) has got enough info on m10s and m40s yet?
m10 and 1/2 =m30, always a good thing! bit more than 1.5 times the capacity though...
Gwynleym10
A couple of things about thte pictures above.
M10s don't usually have the fuse box cover placed on the intake manifold...
They also usually do have a engine driven fan (and a bit of cowling, thoguh smaller than the m40). This particular one had an electrica fan conversion infront of the rad and no radiator cowling, hence alll the dogy tape to increase the flow.....
The pipes around the windscreen washer/suspension turret are for air-con, which is very much needed this time of year! (I use the heated seats during summer
Gwynleym10
Started another thread
http://www.e30zone.co.uk/modules.php?na ... 652#235652
i think the gov is just scaremongering, so that we all don't oppose wind/wave/solar! I know what i would rather on my doorstep! The'll never get planning permission for nuclear powerstations
matt_chase
many thanks for all ur help and advice but im confused????
After looking up parts for my 318i u have 2 choices M10 M40.... But the CC for the m10 engine 1766 M40 is 1795....... my V5 says mine is 1795cc so does that mean ive got an m40 engine?? aaaahhhhh
help!!!
kam-325i
what are the last 7 letters/numbers of your Vin number. ?
Fushion_Julz
Check pics in post near the top...which does it look like?
matt_chase
I think it looks like the M40 picture 95% sure..... 2610246 are the last 7 numbers on the vin number...... From what people are saying this is the worse 1 of the 2..... any advice on what engine to drop in its place.....???
Thanks Guys.....Matt
Fushion_Julz
Yup...that number comes up as an M40, car 10/87 production batch, 2dr manual..
If it were mine, and I wanted something faster/hairier, I'd sell it as standard and buy a 325 or M3 (or possibly a 318is) assuming you wanted to stick with E30s, of course
matt_chase
Thanks Fushion_Julz I wish i had the money to get an M3 Yeah im sticking with the e30's remember this is my first one and i only paid Ԛ£160 for her so i'll enjoy tinkering and hopefully show her off next summer (if we get 1) And if i win the lottery in the mean time......watch this space.... Thanks everyone....cant wait to get her up and running and maybe get to some shows and see some of the other cars on here!!
Fushion_Julz
well..can't complain for Ԛ£160!!
The M40 might not be the motor of choice, but I bet it will respond to a bit of TLC and perhaps a few choice tuning parts (TB, panel filter, etc)...
enjoy it, for that cash you'd be mad not to!
