redcar wrote:I'd recommend going with the e46 067 rack as they're about £40 and are a much easier swap compared to the e36 rack swap. E36 rack requires the hybrid linkage due to the different splines on the e36 rack input shaft. However, you already know that, and by the sounds of it have all the tools to sort out the bits you need
I take it that you're fitting it to an m42 the ?
I'd strongly strongly recommend poly mounts as I wouldn't feel comfortable driving on standard engine mounts with the linkage so close to the manifolds.
I have poly engine mounts on my m42 and some cheap copy e21 gearbox mounts
I've had the rack from a E46 Compact for a while now - 50mm/rev ~2.9 turns lock to lock should make it... erm... pointy
I saw some polybushed mounts available in the US for ~£100 or something
Where did you get yours?
I think I'd prefer rubber mounts to be honest - most of my new suspension bushes are rubber for a reason
(The exception is the anti roll bar bushes - there is no benefit to rubber over polybushes there in my opinion because there isn't the same load transfer through them as there is through, say, the lower control arm bush so it won't increase the harshness of the ride)
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
