shifting trouble
e30lou
hi everyone, i've had a bit of a shifting issue since i've owned my car when engaging 1st gear. to engage it, i have to push it to the left and up(as you normally would) but then let off slightly when i push it left. that's the only way it will engage. anyway, i'm now starting to have trouble shifting from 1st to 2nd, sometimes i really have to fiddle about with the shifter to get it to engage. can anybody suggest what i can do? i saw a post saying changing from SAE80 to ATF Dextron II will help so will give that a go but thought i'd check before going ahead ;)
- **BANNED**
A swap to ATF will lighten the gearshift,but only re-building the linkage will give a decent gear-change.
Ideal oppotunity to install an improved,shorter shift as well.
This will help;
http://www.e30zone.net/e30zonewiki/inde ... ar_Linkage
This will help;
Youth is wasted on the young.
bimanut
Is there any down side to using atf?
e30lou
thanks guys, think i'll just drain the gearbox and try the ATF, see how that goes. if there's no improvement i'll have a go at tackling the linkage rebuild
ATF as in Auto Transmission Fluid ? - The pink stuff ?
Not heard of this before - are the no disadvantages of this ?
- **BANNED**
I use ATF in both of my E30's,Rob,I seem to remember that it is the BMW recommendation for the later ZF built 'boxes!capri_rob wrote:ATF as in Auto Transmission Fluid ? - The pink stuff ?![]()
In the Getrang 'boxes,it will make a worn 'box sound worse,but will give a much lighter shift when cold,as the ATF is thinner than gearoil.
I have been using it for at least 4 years with no ill effects.I started using it when 'er indoors moaned about 'heavy gears!'.....
Might give that a go in mine - I suspect the current gear oil has been in there for 144k
hongkongfuey
- Mad-tango-geezer
i asked the oilman, this question, but i would say do the linkage as well and short shift.
here is the answer i got
oilman wrote:Hi
The Gulf Comp is very good, everyone seems to be loving it.
You need an MTF for the gearbox and I would go with the Redline MTL, Amsoil MTF or Fuchs Sintofluid. The Millers EP or Motul Motylgear 75w-80 are good cheaper alternatives.
http://www.opieoils.co.uk/c-670-75w-80-75w-85-mtfs.aspx
Tim
oilman wrote:Hi
Tim
with cars like mine,
