fuel rail pressure
parkin10
Post Sun Feb 05, 2012 10:52 pm
how long should the pressure stay in the fuel rail for?
i have mpg of around 13-14 miles was thinking that it may be leaking fuel some were very slightly
fuel rail pressure is 3bar and lasts for 20-30 mins
the car is 325 89
and the blue temp sensor works
thanks
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Feb 06, 2012 6:28 am
Fuel pressure should last and last and last. If you park up overnight, fuel pressure should still be there the next morning.
On most it isn't because of a weeping or dribbly injector, but if you're losing it in 20 mins, there's definitely a leak somewhere in the system:
http://www.e30zone.net/e30zonewiki/index.php/Fuel
parkin10
Post Mon Feb 06, 2012 9:29 am
funny thing is i cannot smell any fuel though
Grrrmachine
Post Mon Feb 06, 2012 10:04 am
That probably supports the dribbly injector situation; it's leaking into the cylinders.
The other thing is the rubber fuel hoses might have perished, and the fuel vapour is escaping through the whole pipe, not as a single-point leak, so check them out too.
Normally I'd look at the FPR, but if your mileage is that bad you must have a spillage somewhere.
parkin10
Post Mon Feb 06, 2012 10:19 am
i changed the injectors for a new recon set about august time last year
bad starting they cured it
Post Mon Feb 06, 2012 1:46 pm
Clamp off the fuel lines and see what effect that has.
parkin10
Post Mon Feb 06, 2012 3:09 pm
clamped the line to the rail got 5 bar fell to 4bar in 20mins
cannot see any fuel leaks
its taken me along time to get this motor to run well and now it does it really drinks it :roll:
i am only using the car on the school run though
so i not getting the motor hot really may be that does not help my mpg :cry:
clipper
Post Mon Feb 06, 2012 4:31 pm
I only found my petrol line leak after running my fingers along ALL of the fuel lines until I found a wet bit, it was only a hose clip that had jumped a thread from being over-tightened and it couldn't be seen or smelled.
parkin10
Post Mon Feb 06, 2012 5:37 pm
what size are the fuel pipes?
guess i will have to change all the pipes
kman82
Post Mon Feb 06, 2012 5:58 pm
How much pressure are you loosing? I think I read somewhere that it is within spec if it looses something like 1bar of pressure after 30 minutes - someone else should be able to confirm that though.
you should be able to work out where you are loosing pressure from by clamping off the pipes at various points rather than replacing them - they are very expensive from bmw!
I had this problem recently and Brian helped no end with this post:
Brianmoooore wrote: Connect up your pressure gauge, run the engine and switch off to confirm that residual fuel pressure is your problem, then repeat, but immediately after switching off, clamp off the fuel hose that runs from the FPR., and see if this maintains pressure. Repeat again, but this time clamp the hose that goes directly to the fuel rail, before where you've teed the gauge in.
If first test maintains pressure, it points towards a duff FPR; if the second test maintains pressure, the non return valve in the pump is the problem.
If neither test maintains pressure, then one or more injectors are the problem.
All assume that there are no simple leaks.
Grrrmachine
Post Mon Feb 06, 2012 6:06 pm
kman82
Post Mon Feb 06, 2012 6:16 pm
the two fuel hoses within the engine bay cost me £50 to replace recently.
I couldn't find that size from a motor factors so had to go to bmw
Grrrmachine
Post Mon Feb 06, 2012 6:22 pm
I bought mine on ebay for a tenner :D Genuine BMW stuff, still used in brand new Minis.
rrs
Post Mon Feb 06, 2012 7:06 pm
Sytec make a fuel injection hose with the correct I/D and O/D, I bought 6m for about £15.
parkin10
Post Mon Feb 06, 2012 9:49 pm
kman82 wrote:the two fuel hoses within the engine bay cost me £50 to replace recently.
i have to say that every part from bmw costs a mint
i wanted to change the vacuum hose on the servo bmw wanted £22 plus vat i got mine from hoselines for £4 it is exactly the same as what came off
http://www.hoselines-catalogue.co.uk/default.aspx
i am planing to use hoselines for the fuel pipe too
