Hi,was wondering if this diff will fit on my 2.5 e30 touring
Ben
e36 lsd info please
AFAIK, diff will fit (assuming they're both 188 size) , casing will not. Insides need to be built into an E30 case, which isn't a DIY job.
bjg16v
Thanks, the diff is off a e36 323 if that tells you any thing,i havnt a clue
I would expect that to be a 188 (medium case diff.), but the ratio will be totally unsuitable for an E30 gearbox - somewhere around 3:1, I'd expect.
bjg16v
Ok thanks for your help,wont even bother going there with that then,just save up for a sport one.
